i had a similar problem like this except my window would fly down and then go up snail speed on both driver and pass. i ripped apart the driver side even cut out the regulator and then i found out the contacts in the switch itself were corroded with green sh*t and wiped all that off and put the switch back together and then had to rivet the regulator back on. and piece it together i was pissed. so check those contacts.
