Thread: Abs/tcs problem
Results 1 to 7 of 7
L KELLS Abs/tcs problem 01-03-2010, 10:11 PM
KawaFord Re: Abs/tcs problem 01-03-2010, 10:17 PM
L KELLS Re: Abs/tcs problem 01-03-2010, 10:38 PM
KawaFord Re: Abs/tcs problem 01-03-2010, 10:47 PM
badbrad Re: Abs/tcs problem 01-04-2010, 03:41 PM
KawaFord Re: Abs/tcs problem 01-04-2010, 03:46 PM
Jakegday Re: Abs/tcs problem 01-04-2010, 04:51 PM
  1. #1 Abs/tcs problem
    SE Level Member L KELLS's Avatar
    Chicago
    On. Here's the problem. I. Have a tcs light on on the dic bur the abs light s off. The system do it self test when the key is turned but about a minute or so the tcs light pops on and stays on until I turn off the car. And ideas
  2. #2 Re: Abs/tcs problem
    GXP Level Member
    Theworld
    bad wheel bearing sensors...
    Do a google search, this has been talked about tons of times.
    There's a guide in the "How To" section on replacing the hub.
  3. #3 Re: Abs/tcs problem
    Chicago
    Wouldn't that trigger the abs light too and not just the tcs light
  4. #4 Re: Abs/tcs problem
    GXP Level Member
    Theworld
    Miss-read that, but yeah, it would.
    Not sure then.
  5. #5 Re: Abs/tcs problem
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    there is a fuse under the hood for the abs/tcs on the same fuse....check it.....when i remove mine it'll do a hellacious burnout!
  6. #6 Re: Abs/tcs problem
    GXP Level Member
    Theworld
    Quote Originally Posted by badbrad View Post
    Wouldn't turning the TCS off have the same effect..?
  7. #7 Re: Abs/tcs problem
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    yes...
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  1. Yet another A/C problem
    By TexasFury in forum General Tech Discussion
    Last Post: 09-23-2009, 12:32 PM
  2. big problem!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 07:56 PM
  3. HUD problem
    By the1euge in forum General Tech Discussion
    Last Post: 08-31-2009, 12:23 PM
  4. AC problem
    By MDCruzer in forum General Tech Discussion
    Last Post: 06-12-2009, 08:36 PM
  5. What is the problem?
    By spidamanSS in forum General Tech Discussion
    Last Post: 05-07-2008, 12:56 AM
