Thread: Shift lock
Results 1 to 7 of 7
  1. #1 Shift lock
    Nov 2009
    Nebraska
    Every time I try to shift from park I need to push the shift lock release button, in order for the shifter to move any. What can I do to fix this? Its getting old after one day of haveing to push the button.
  2. #2 Re: Shift lock
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    This happened to me once. I had a bad starter a while back, when my mechanic installed the new one they knocked loose a ground wire..That ground wire controled my radiator fans so the car was overheating. Thats when the shifter became locked. Well I took the car to another shop and by re-grounding the wire the shifter worked fine again. Sooo most likely its a loose wire or some sh!t. Could be something else tho
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  3. #3 Re: Shift lock
    Nov 2009
    Nebraska
    so where is this grounding cable located? Is that really all it can be?
    Thanks
  4. #4 Re: Shift lock
    Charles City, IA
    There is a solenoid by the shifter that sticks. Check for broken wires going to it to. It is under the center consul.
    SMGPFC Two Nipple General
  5. #5 Re: Shift lock
    Banned - Busted For Scamming
    Feb 2009
    They commonly go bad as well.
  6. #6 Re: Shift lock
    Charles City, IA
    Just remembered.
    My cousins girlfriends (i know very closely related) car was doing this. When I took apart the center consul there had to be like 3 bottles worth of coke split down there and a bag of chips split. Fat *****. Have fun seeing what is in your car.
  7. #7 Re: Shift lock
    Reading, PA
    mine was on a ledge type piece of metal under were the MAF is
  1. Stuck In Park. Shift Lock Release Doesnt Work.
    By SilverGT in forum General Tech Discussion
    Last Post: 07-24-2012, 01:23 PM
  2. Shift lock solenoid
    By richard58 in forum General Tech Discussion
    Last Post: 11-17-2009, 04:45 AM
  3. car lock
    By smittrailfire in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2009, 01:17 PM
  4. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
  5. Lock?
    By mlambert in forum Visual/Body Modifications
    Last Post: 01-10-2008, 09:37 AM
