Thread: No Heat, Need Help.
Results 1 to 12 of 12
  1. #1 No Heat, Need Help.
    NJ
    Hello All, I have a 2006 Grand Prix and it now has no heat. I bled the coolant system and there are no leaks. I cant figure out what the problem is. Any suggestions would help. Thanks in advance.
  2. #2 Re: No Heat, Need Help.
    GTX Level Member bronzemist02's Avatar
    Canada
    Are the fan settings working? If not it could be blower motor, fuses, something of that nature.
  3. #3 Re: No Heat, Need Help.
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Quote Originally Posted by speed24 View Post
    Don't turn on the a/c and play with the temp control knob. Will the temperature change any at all when you adjust the temp. control? I don't mean enough to where you thank you can tell. I mean from cold to a little warm. Just trying to figure out if it's the temp control module itself or something else. GMs HVAC controls are exactly good.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  4. #4 Re: No Heat, Need Help.
    PA
    Why did you bleed the coolant system? Did you do this to try and fix your no heat problem? Or did you bleed the coolant system, then you found you have no heat?
    Check the simple things first. Make sure your radiator is full of coolant. If your car has a radiator cap, remove that, and make sure the radiator is full to the top. Note that the radiator cap is different from the overflow tank.
    2001 GSE
  5. #5 Re: No Heat, Need Help.
    NJ
    I bled the coolant system to try and solve the no heat problem because thats what an older post on here said to try. I tried changing the temperature knob with the A/C off and the temperature didnt change. How do I get to the temperature control module, if that is the problem? thanks for all the quick responses, it is much appreciated.
  6. #6 Re: No Heat, Need Help.
    PA
    Did you check the coolant level in the radiator?
    2001 GSE
  7. #7 Re: No Heat, Need Help.
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    id check the heater core. if its blowing air but not hot air then your fan and controls work. its prolly the heater core or the heater control valve. i could be wrong but i diagnose these all day at work and that usually is the culprit. good luck
  8. #8 Re: No Heat, Need Help.
    NJ
    thanks for the help, but if the heater core was bad, wouldnt it leak? Could the heater core be clogged? Should I try flushing it? Once again thanks for all the help.
  9. #9 Re: No Heat, Need Help.
    Nov 2009
    Michigantown, IN
    its possible for the core to be bad and not leak. you could prolly go to a local shop and have it fixed for cheap.
  10. #10 Re: No Heat, Need Help.
    PA
    Did you check the level of the coolant in the radiator?
    2001 GSE
  11. #11 Re: No Heat, Need Help.
    NJ
    i will check the coolant level in the radiator in a little while because the engine is still hot.
  12. #12 Re: No Heat, Need Help.
    NJ
    The radiator is full so i flushed the heater core and now the heat works. Thanks for all the help guys.
  1. no heat
    By 71dang in forum General Tech Discussion
    Last Post: 10-28-2009, 12:34 AM
  2. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  3. Heat and A/C??
    By lorenzojay in forum General Tech Discussion
    Last Post: 09-28-2009, 08:43 PM
  4. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
  5. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
