Thread: No Heat, Need Help.
Results 1 to 12 of 12
  1. #1 Re: No Heat, Need Help.
    NJ
    I bled the coolant system to try and solve the no heat problem because thats what an older post on here said to try. I tried changing the temperature knob with the A/C off and the temperature didnt change. How do I get to the temperature control module, if that is the problem? thanks for all the quick responses, it is much appreciated.
  2. #2 Re: No Heat, Need Help.
    PA
    Did you check the coolant level in the radiator?
    2001 GSE
  3. #3 Re: No Heat, Need Help.
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    id check the heater core. if its blowing air but not hot air then your fan and controls work. its prolly the heater core or the heater control valve. i could be wrong but i diagnose these all day at work and that usually is the culprit. good luck
  1. no heat
    By 71dang in forum General Tech Discussion
    Last Post: 10-28-2009, 12:34 AM
  2. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  3. Heat and A/C??
    By lorenzojay in forum General Tech Discussion
    Last Post: 09-28-2009, 08:43 PM
  4. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
  5. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
