Thread: No Heat, Need Help.
Results 1 to 12 of 12
  1. #1 Re: No Heat, Need Help.
    NJ
    thanks for the help, but if the heater core was bad, wouldnt it leak? Could the heater core be clogged? Should I try flushing it? Once again thanks for all the help.
  2. #2 Re: No Heat, Need Help.
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    its possible for the core to be bad and not leak. you could prolly go to a local shop and have it fixed for cheap.
  3. #3 Re: No Heat, Need Help.
    PA
    Quote Originally Posted by speed24 View Post
    Did you check the level of the coolant in the radiator?
    2001 GSE
  1. no heat
    By 71dang in forum General Tech Discussion
    Last Post: 10-28-2009, 12:34 AM
  2. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  3. Heat and A/C??
    By lorenzojay in forum General Tech Discussion
    Last Post: 09-28-2009, 08:43 PM
  4. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
  5. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
