Thread: Car wont rev..
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #1 Re: Car wont rev..
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    let us know how it turns out
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  2. #2 Re: Car wont rev..
    GTP Level Member SuperSport's Avatar
    Michigan
    Drop the exhaust and check for a clogged cat, because thats your problem. Mine did the same thing. Would idle fine, but would just buck and jump in gear.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Car wont rev..
    Quakertown, PA
    I've been following this thread and I am just wondering....how does one "check for a clogged cat" by dropping the exhaust? Can you tell just by looking at it?
  4. #4 Re: Car wont rev..
    GEORGIA
    look inside of it and c if its falling in2 pieces on the inside i guess. i got mine fixed. oil pressure sensor.
  5. #5 Re: Car wont rev..
    May 2008
    staten island,NY
    ding ding ding i was right!!!!! glad you fixed it
  6. #6 Re: Car wont rev..
    romeoville, il
    so it was a clogged cat!!!
  1. my key wont
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 11:38 PM
  2. 97 fires but wont run.
    By clh97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2009, 10:08 PM
  3. 93 with 3.1 wont start!
    By rvdavis in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-02-2009, 05:27 PM
  4. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
  5. need help GP wont run
    By uti grand prix in forum General Tech Discussion
    Last Post: 10-29-2008, 06:23 AM
car, rev
