Thread: Car wont rev..
Results 1 to 20 of 26
  1. #1 Car wont rev..
    romeoville, il
    My '99 gtp will not rev past 2500rpms. It jerks, bucks, goes up and down during driving. There is no power. With very little throttle driving is okay. The car idles perfectly. When trying to rev the car the motor shakes and sounds like the supercharger is falling apart.
    The car through a po300 code (multiple cylinders misfire).
    The fuel presser is 42 at idle and goes up while accelerating. I switched the coil packs and ignition module and the car still runs the same.
    Any other ideas?
  2. #2 Re: Car wont rev..
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    plugs and wires, clogged cat converter, injectors, no compression, computer, could be many things.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: Car wont rev..
    romeoville, il
    im gonna do plugs and wires tomorrow and im also gonna get a compression tester.
    i really hope it is NOT the computer..
  4. #4 Re: Car wont rev..
    GEORGIA
    well u can find 1 cheap anyway. start cheap and work ur way up.
  5. #5 Re: Car wont rev..
    romeoville, il
    what makes you think its the computer? jw
    i just bought this car for a daily driver less than a year ago and i dont know much about them. are they known for the computers going out?
  6. #6 Re: Car wont rev..
    GEORGIA
    not really, but u never know. ive seen cars with messed up computers and they barley run.
  7. #7 Re: Car wont rev..
    romeoville, il
    okay..thanks! if you think of anything else PLEASE let me know! i have to have this car fixed by sunday if i can!
  8. #8 Re: Car wont rev..
    GEORGIA
    i know how u feel. my car messed up 2day. oil everywhere. gettin it fixed this weekend 2.
  9. #9 Re: Car wont rev..
    romeoville, il
    my cars been down since tuesday and i live in chicago and the first snow storm hit tues and wednesday so there is no way i can drive my trans am so im stuck at home until its fixed
  10. #10 Re: Car wont rev..
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Quote Originally Posted by firehawkchick55 View Post
    Any other ideas?
    Might be a completely shot intake gasket or head gasket. How does your engine oil and coolant look? Did you just get it, or have had if for a while? I bought my GTP with a miss. Oil in the coolant. Bet a friend. He said intake gasket. I said head gasket. $500 bet FTW! lol
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  11. #11 Re: Car wont rev..
    romeoville, il
    the car ran perfect the night before this happened. i shut the car off like i normally do and the next day this is what i woke up to.
    i just changed the oil yesterday and it was fine. the coolant is fine and there is no oil in it.
    i've had the car since april or may i think im not exactly sure it could've been june lol
  12. #12 Re: Car wont rev..
    GEORGIA
    new intake gaskets a month ago. car is not overheating so it cant be the head gaskets, no coolant in the oil and vise versa. i was told it could be a front main seal, oil pan gasket, timing cover gasket.
  13. #13 Re: Car wont rev..
    romeoville, il
    a car does not have to over heat in order for it to be a head gasket...some cars even run cool when it has a blown head gasket
  14. #14 Re: Car wont rev..
    GEORGIA
    but it runs perfect. just oil all underneath the car. ifit was a head gasket it be all under the hood on the motor.
  15. #15 Re: Car wont rev..
    romeoville, il
    true..do a compression test and make sure though..
  16. #16 Re: Car wont rev..
    GEORGIA
    oh car is still running strong and gr8, no issues but the oil leak. blown head gasket, it b running like crap, throwing misfires cause of bad compression.
  17. #17 Re: Car wont rev..
    romeoville, il
    i wonder if mines the headgasket..
    oh i just thought of something...
    do you think it could be bad fuel? i just filled up the night before all this happened?
  18. #18 Re: Car wont rev..
    GEORGIA
    could be, happens all the time. change the fuel filter and put some seafoam in it.
  19. #19 Re: Car wont rev..
    May 2008
    staten island,NY
    sounds like a clogged cat
  20. #20 Re: Car wont rev..
    romeoville, il
    okay so i have a list of things to do tomorrow..
    1. drop exhaust to see if its a clogged cat
    2. compression test
    3. new plugs & wires
  1. my key wont
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 11:38 PM
  2. 97 fires but wont run.
    By clh97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2009, 10:08 PM
  3. 93 with 3.1 wont start!
    By rvdavis in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-02-2009, 05:27 PM
  4. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
  5. need help GP wont run
    By uti grand prix in forum General Tech Discussion
    Last Post: 10-29-2008, 06:23 AM
car, rev
