Thread: need help GP wont run
Results 1 to 5 of 5
  1. #1 need help GP wont run
    Jul 2008
    my car when it is at idle will not stay at a normal idle it will idle rough and the dic screen will say traction control off. service tration system and reduced engine power. then it wont move more than like .5 mph. it throws a check engine code which is P0507. im not sure where to start looking for the problem or if i should just take it to a shop to have it worked on but i would perfer to do it my self. if you ahve any ideas as to what could be wrong with it let me know any help is great.
  2. #2 Re: need help GP wont run
    Feb 2008
    DTC P0507 = Idle Speed High
    Check this link out to track down what the problem is.
    First thing I would recommend tho is to do a tune up, and make sure to check your coolant level. Go through all of your electrical connections and make sure they are all connected correctly and make sure that all of your vacuum lines are in good shape(not cracked) and replace or repair as needed.
    Good luck!!
  3. #3 Re: need help GP wont run
    Jul 2008
    i did just remember that i changed the pcv valve about 3 weeks ago and it started to do it later that week. could that have anything to do with it? Or could it have to do with a vacuum problem?
  4. #4 Re: need help GP wont run
    Feb 2008
    What engine do you have? 3.1L or 3.8L?
  5. #5 Re: need help GP wont run
    Jul 2008
    3.8 series 3
  1. car wont stay running
    By 98gpgtp in forum General Tech Discussion
    Last Post: 04-17-2010, 07:41 AM
  2. car wont start
    Last Post: 10-22-2008, 05:26 PM
  3. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
  4. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
  5. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
run
