Thread: Built Heads or IC?
Results 1 to 9 of 9
  1. #1 Built Heads or IC?
    Nov 2008
    Searcy,Arkansas
    What would be better....not trying to be "cocky" but money is not a issue. I been looking at some heads from ZZP and was wondering if I should build the motor and tranny up then get a IC. And also im REALLLLLLLLLLY leaning towards a turbo setup after the first of the year. Just wanting your guys two cents on it all!
  2. #2 Re: Built Heads or IC?
    heads wont help you with that VS cam, get an intercooler.
  3. #3 Re: Built Heads or IC?
    Charles City, IA
    If going to get a turbo just save up for that.
    SMGPFC Two Nipple General
  4. #4 Re: Built Heads or IC?
    SE Level Member 03impala9c1's Avatar
    Nov 2009
    Appleton WI
    heads honestly dont do too much... i mean they do, but not for the money. i ran a gen v 2.55 ic setup all the way to low 12's on BONE stock heads minus valve springs. a buddy ran his turbo setup into the 11's no prob on BONE stock heads. 0kr. im sure there is 10-15hp to be picked up with built heads but at what cost? 1500+??? No thanks. IC is the way to go. and if i were you, i wouldnt be investing into turbo setups but thats just my .02. you will be fixing it more than driving it more than likely.
    96 z/28 headers, cam, 3.73's, n2o, etc. - cant wait to bring her outta storage.
    99 gtp 3.0 nic l32 built trans and susp. sold
    99 regal gse t66 t3t04e zzp trans l32 stattama custom cam HUGE spearco a2a ic sold
    98 gtp 3.4 built susp sold
  5. #5 Re: Built Heads or IC?
    Quote Originally Posted by 03impala9c1 View Post
    Heads are worth it...IMO...if your paying $1,500 for 3800 heads your getting hosed.
  6. #6 Re: Built Heads or IC?
    Charles City, IA
    $1500 for heads? Mine were done for under $500 including valve job, valve seals and magnafluxed.
  7. #7 Re: Built Heads or IC?
    yes, heads arent worth it if you arent using the extra flow that becomes available. big cam = ported heads.
  8. #8 Re: Built Heads or IC?
    Jan 1970
    Maquoketa, Iowa
    Just get the aluminum heads and a genV ic setup if money is not the issue! But I might have to remarry you if you do that... Stock heads have been pushed past 600whp before. Your going to see more noticable gains from an intercooler, at least a pulley size and 3-4 degrees of timing. You will also be able to run the car a little leaner on a IC setup.
  9. #9 Re: Built Heads or IC?
    Nov 2008
    Searcy,Arkansas
    Quote Originally Posted by FoSHO99 View Post
    Ya..I just bought Aluminum heads from ZZP and a IC...rmm would that be okay?
  1. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  2. Aftermarket wires that need to be built
    By 04muscle in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2009, 09:08 PM
  3. I built a heads-up display (HUD).
    By drranu in forum General Tech Discussion
    Last Post: 08-19-2008, 06:30 PM
  4. Replies: 18
    Last Post: 08-07-2008, 05:15 AM
  5. s1x and built transmission
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2008, 04:56 PM
