Thread: Another HUD problem
Results 1 to 5 of 5
SlowPurpleGTP Another HUD problem 03-09-2008, 11:48 PM
SyntheticShield Re: Another HUD problem 03-10-2008, 12:00 AM
SlowPurpleGTP Re: Another HUD problem 03-10-2008, 09:17 AM
SyntheticShield Re: Another HUD problem 03-10-2008, 09:21 AM
archemedes Re: Another HUD problem 03-10-2008, 05:51 PM
  1. #1 Another HUD problem
    Lafayette Indiana
    Ok... I bought the car back in November and my HUD hasn't worked since I got it. I've done some searching on possible problems but all I ever find is the typical brightness issues. I don't know a whole lot about HUD systems so I'm not quite sure how to trouble shoot my problem other than check fuses. Any tips would be greatly appreciated.
  2. #2 Re: Another HUD problem
    Oklahoma
    Well, dont take this the wrong way. I only mention it because the first couple of days I had mine I thought the HUD didnt work either until I realized that you could adjust the tilt angle. Someone or the previous owner had it tilted all the way down so that it didnt show up.
    So I would off that up as a suggestion. Ive never really heard of any HUD issues outside of the brightness issue.
  3. #3 Re: Another HUD problem
    Lafayette Indiana
    yea I already checked the tilt... checked the brightness... nothing
  4. #4 Re: Another HUD problem
    Oklahoma
    Quote Originally Posted by SlowPurpleGTP View Post
    Okay, carry on then. Just thought I would ask so we could rule it out. Aside from it being just bad and needing to be replaced, the only other thing I can think of would be to check the fuses.
  5. #5 Re: Another HUD problem
    Saraland Alabama
    if the fuses are good it almost has to be the unit (could be a bad wire leading to it, or switch) how much does Ed charge for the unit and switch, might be worth swapping it
  1. Ignition Problem.
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 07:49 PM
  2. Oil leak problem
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 05:24 AM
  3. DHP scanner problem
    By monte0 in forum PCM Tuning
    Last Post: 02-13-2008, 04:39 PM
  4. Wiper problem again
    By Fish in forum Visual/Body Modifications
    Last Post: 02-01-2008, 03:22 PM
  5. still got a problem
    By idriveamazda in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-24-2008, 04:36 PM
