Thread: DHP scanner problem
Results 1 to 7 of 7
monte0 DHP scanner problem 02-13-2008, 07:16 AM
SyntheticShield Re: DHP scanner problem 02-13-2008, 08:13 AM
monte0 Re: DHP scanner problem 02-13-2008, 12:52 PM
SyntheticShield Re: DHP scanner problem 02-13-2008, 12:53 PM
monte0 Re: DHP scanner problem 02-13-2008, 04:38 PM
Reptile Re: DHP scanner problem 02-13-2008, 03:03 PM
monte0 Re: DHP scanner problem 02-13-2008, 04:39 PM
  1. #1 DHP scanner problem
    NY
    Weird problem here, every time I go do a scan the scanner freezes up/stops responding, but you can cancel out of it with no problems. I've checked everything and nothing seems to be causing it. Reinstalled the Keyspan drivers a few times and checked all connections. Tried reinstalling the tuner software a few times and still nothing helps. Could the Keyspan adapter be bad? **Also, the other night I reflashed the pcm and the car started shuttering at WOT. Did another partial flash and still doing it, so I did a full flash and all is good. Could these be both related issues?? thanks in advance guys
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
  2. #2 Re: DHP scanner problem
    Oklahoma
    I could be off base here, so take it for what its worth, but I thought I had read somewhere that if you ran into that type of problem that you should slow the baud rate or something like that.
    I have a DHP Tuner but I have never run into that issue before.
  3. #3 Re: DHP scanner problem
    NY
    I have tried that too with no luck...it acts up when it feels like it
  4. #4 Re: DHP scanner problem
    Oklahoma
    I wish I knew what to tell ya, but I just dont have that much quality time with my tuner. I assume you have tried the DHP forums?
  5. #5 Re: DHP scanner problem
    NY
    yea, I've tried. Hard to get any responce over their.
  6. #6 Re: DHP scanner problem
    Bastard Reptile's Avatar
    Kansas City, MO
    I've had that problems with the 1.2.2 version...went newer and no more problems.
  7. #7 Re: DHP scanner problem
    NY
    Quote Originally Posted by Reptile View Post
    I'm running the 1.2.4 version and havent had a issue with it till just a few months ago when things started acting up.
  1. Anyone in North NJ w/a scanner?
    By TJs97 in forum Northeast
    Last Post: 03-17-2008, 03:55 AM
  2. Oil leak problem
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 05:24 AM
  3. still got a problem
    By idriveamazda in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-24-2008, 04:36 PM
  4. Scanner you can use with a PDA or Laptop?
    By Blue03GTP in forum PCM Tuning
    Last Post: 01-13-2008, 11:29 PM
