Thread: mpg?
Results 41 to 60 of 64
  1. #41 Re: mpg?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by blowfishRus6 View Post
    if you dont feel like dishing out the money for the egr you can just delete it. many have done this and reported no change in gas milage.
    Then they are full of poop, drive like maniacs, or have other underlying issues. The EGR does improve fuel economy under normal driving conditions.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  2. #42 Re: mpg?
    Troy OH
    i can get the same mpg at 80 that i can at 60. i dont think that matters.
    does the older models not tell you instant gas econemy??? that helps alot with trying to save gas. the way you drive it has ALOT to do with it also. you may think your taking it easy, but you could do better im sure.
    you're definitely the exception, not the rule. mine goes down 2mpg at 80.
    how many miles to the tank are you getting? divide that by 12 and you'll get a good reading just in case the wheels are throwing your computer off. that makes sure you actually have a problem haha. defintely check the O2 sensors, i changed my front one and MAF at like 125,000 due to codes, that was like 5 mpg and it ran so much better. it could be where you drive it too, these cars are thirsty in town, i'm lucky to get 20 and my engine's clean. and since nobody's mentioned it, could be air filter/dirty plugs if you're over 100k, just little things like that. look into some of these and you could save yourself some money
  3. #43 Re: mpg?
    Troy OH
    please disregard. missed the second two pages lol.
  4. #44 Re: mpg?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by JoshMcMadMac View Post
    i too was under the impression that removing the EGR negatively affects gas mileage. if i remember correctly, you can get an egr block off plate from zzperformance.com, and in the description, it says it will lower your mpg a little bit
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  5. #45 Re: mpg?
    Waynesboro, PA
    Quote Originally Posted by Jakegday View Post
    You can also RTV a penny over each of the two holes.
  6. #46 Re: mpg?
    Wausau, WI
    I thought it was one penny and one nickel? or dime? I cant remember....not like it really matters. Use whatever fits best.
  7. #47 Re: mpg?
    SE Level Member bensett004's Avatar
    michigan
    brand new air filter, not sure on the plugs, i know there not stockers tho....
    fwi, kn filter, 3 in down pipe, power log, 180* thermostat, 10000k hids and soon to come a dhp pcm
  8. #48 Re: mpg?
    Wausau, WI
    do you have a gt? 3.29 gears?
  9. #49 Re: mpg?
    michigan
    can some one point me in a direction to clean my maf, i also heard cutting the gasket in there helps some to, not for mpg, just helps
  10. #50 Re: mpg?
    Nov 2008
    Fremont Nebraska
    go to an auto parts store and pick up a can of "maf cleaner"
    spary your maf and your done. you will need a set of "security torx" bits to get it out though
  11. #51 Re: mpg?
    Wausau, WI
    you take out your MAF sensor, clean it with MAF cleaner(dont scrub it) and put it back in...never heard of cutting the gasket
  12. #52 Re: mpg?
    michigan
    the throttle body gasket, it hangs in side or some crap? idk i read it somewhere, cant remember where..... i have a gtp
  13. #53 Re: mpg?
    SCRUB THE MAF?!?!?! Are you crazy? Thta thing is sensitive enough by just spraying it with a higher pressure cleaner...let alone scrubbing it...DONT DO THAT.
  14. #54 Re: mpg?
    the EGR doesnt help dick for mileage if you tune your car properly. **** that noise.
  15. #55 Re: mpg?
    Troy OH
    definitely. that's an expensive piece of plastic too, a refurbished one after the core charge ran me like $140. there's no gasket, but there's a mesh screen that's in front of the MAF. taking that out leads to a little better air flow but the sensor's right in the middle of the intake. if your filter doesn't get EVERYTHING then you need another new MAF, your call.
  16. #56 Re: mpg?
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    Perfectly said.... also only use MAF Cleaner. Definitely dont use carb or brake cleaner.
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  17. #57 Re: mpg?
    Wausau, WI
    OK...I should have said dont scrub it at all....dont physically touch it (the sensor portion....) spray it only. I stated it above very poorly
  18. #58 Re: mpg?
    Donating Users blowfishRus6's Avatar
    g.a.
    i use brake cleaner all the time on mine. so far it hasent hurt anything....
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  19. #59 Re: mpg?
    Middleboro, Ma
    Thats just one of those things you hear from multiple sources so you trust it to be good information...
    1989 Sierra:
  20. #60 Re: mpg?
    g.a.
    wuutttt ??
    its slow.
mpg
