Thread: Auto start or security system
Results 1 to 7 of 7
Threaded View
  1. #7 Re: Auto start or security system
    SE Level Member docmafia's Avatar
    Mob Missouri
    Something about taping your key in the steering column just doesn't sit right with me. A theft is going to tear into that steering column and see that key sitting there and then he's going to think to himself "Jackpot". I bought a 20.00 bypass to out on my remote start/Alarm system, so my Pass-Key III still works and there is no hidden key in my steering column.
    I just started to install mine on a 2001 Grand Prix GTP and the only trouble i'm having is trying to find a rearm wire for the factory alarm system. I have looked at more pages of wiring diagrams then all the Harry Potter books combined, and none of them have a rearm wire labeled. I went to my local GM Dealer and all they could say is "Geeee, I don't Know" But what did I expect coming from a small redneck town. I can't even figure out the doors and windows, and it's already took a huge dump of snow on us. So i'm waiting till it warms up before finishing the rest but at least my alarm/remote start work and I can start my car from a mile a way which came in handy yesterday when I had to go to super wal-mart in a blizzard, I started my car all the way from the back of the store that's convenience!
    Here's the wiring diagram for a 2001 grand prix
     PART COLOR LOCATION
    12 VOLT CONSTANT RED (+) and RED/WHITE (+) IGNITION SWITCH HARNESS
    STARTER YELLOW (+) IGNITION SWITCH HARNESS
    STARTER 2 N/A
    IGNITION 1 PINK (+) IGNITION SWITCH HARNESS
    IGNITION 2 WHITE (+) IGNITION SWITCH HARNESS
    IGNITION 3 N/A
    ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS
    ACCESSORY/HEATER BLOWER 2 N/A
    KEYSENSE N/A
    PARKING LIGHTS ( - ) N/A
    PARKING LIGHTS ( + ) BROWN (+) @ HEADLIGHT SWITCH
    POWER LOCK LIGHT BLUE (Negative (-)) IN DRIVERS KICK PANEL
    POWER UNLOCK WHITE (Negative (-)) IN DRIVERS KICK PANEL
    DOOR TRIGGER See NOTE *1 IN DRIVERS KICK PANEL and PASSENGER KICK PANEL
    DOMELIGHT SUPERVISION TAN (-), Requires Part # R30-H Relay IN DRIVERS KICK PANEL
    TRUNK RELEASE BLACK/WHITE (+), Requires Part # R30-H Relay @ TRUNK RELEASE SWITCH
    SLIDING POWER DOOR N/A
    HORN BLACK (-) @ STEERING COLUMN HARNESS
    TACH WHITE @ PCM, Connector 2, Pin 8, See NOTE *2
    WAIT TO START LIGHT N/A
    BRAKE WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
    FACTORY ALARM DISARM ORANGE/BLACK (-) IN DRIVERS KICK PANEL
    ANTI-THEFT GM's PASSKEY 3 (PK3 on Steel Shaft of Ignition Key) TRANSPONDER TRANSPONDER @ IGNITION SWITCH TUMBLER
    EXTRA INFORMATION
    NOTE *1 the DRIVERS DOOR is a TAN (-) in the DRIVERS KICK PANEL and the DARK BLUE (-) in the PASSENGER KICK PANEL is for all other doors. When connecting to an ALARM SYSTEM, use both DOOR TRIGGER wires and DIODE ISOLATE. to connect, See DIAGRAM NOTE *2 the PCM (Powertrain Control Module) is in the Air Cleaner Assembly.
  1. Security system
    By musiknjoyr in forum Audio, Security & Visual Electronics
    Last Post: 12-09-2009, 10:43 AM
  2. Stock Security System
    By Meg99GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2009, 10:06 AM
  3. new to the site-- need some security system help
    By sara2344566 in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:33 PM
  4. factory security system problem
    By TJs97 in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2009, 12:44 AM
  5. Stock Security System freaked out on me...
    By evol207girl in forum General Tech Discussion
    Last Post: 11-24-2008, 11:56 PM
