Thread: Changing out blower fan
Results 1 to 7 of 7
  1. #1 Changing out blower fan
    SE Level Member Space Ace's Avatar
    Missouri
    I have a 2001 Grand prix 3.1L that when I turn up the blower fan inside, it starts to vibrate quite loudly anwhere above low (1). How hard and where do I have access to the blower motor? Is it behind glovebox like most?
    Thanks
  2. #2 Re: Changing out blower fan
    It is actually up under the dash. I've never done one, but understand it's not that bad of a job to wing.
  3. #3 Re: Changing out blower fan
    new orleans
    its not a bad job at all...under the passenger side...i believe its like 4 bolts...don't remember..i had to take it out to replace the blower motor resistor
  4. #4 Re: Changing out blower fan
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    Yup take out the three plastic pieces holding the plastic shroud up and remove the shroud. The blower motor is way up in front by the firewall. Disconnect the wire going to the motor and unscrew the three little bolts/screws. The blower motor should just drop right down. Very easy to do. The hardest part is finding a comfortable way to squeeze in there. Oh and it's recommended to disconnect the battery while doing this.
  5. #5 Re: Changing out blower fan
    Missouri
    Quote Originally Posted by dirtmaster88 View Post
    Dirtmaster88, what plastic shroud are you talking about. Is it after you remove glovebox , etc?
  6. #6 Re: Changing out blower fan
    Sheboygan, WI
    Quote Originally Posted by Space Ace View Post
    Just the piece of plastic by your feet that's covering everything up. Right below the glovebox. Glovebox does not need to be removed, just this plastic piece by your feet.
  7. #7 Re: Changing out blower fan
    Missouri
    Thanks, everyone that make my job a lot easier!
  1. i need help on changing supercharger oil
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2009, 02:21 AM
  2. Oil Information / Changing
    By gahris in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-12-2009, 10:10 AM
  3. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
  4. changing supercharged oil
    By nemesis in forum General Tech Discussion
    Last Post: 08-06-2008, 12:27 PM
  5. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
