Thread: Boost BYpass Valve capped Off?????
Results 1 to 20 of 21
  1. #1 Boost BYpass Valve capped Off?????
    Donating Users Uno99's Avatar
    Appleton, Wi
    OK so ive been wondering why my cam'd 3.2 setup GTP was only running a best of 14.05@101mph at the track. NOW BE NICE IM A 3800 newb and new to BOOST. Even after a headgasket and header install my friends and I failed to notice the BBV was capped off. (pics below) We noticed this when we were finishing up welding up my OBX headers this weekend. In the first pic below you can see the 2 inch little rubber hose with a screw in the end of it plugging it up. I think my buddy did this when I first bought the car and tried putting my ported throttle body on it. I took the rubber hose off and its a whole new animal. However Im gonna be safe and take it easy until I can scan it for knock and re-tune.
    WRONG
    RIGHT
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  2. #2 Re: Boost BYpass Valve capped Off?????
    Donating Users blowfishRus6's Avatar
    g.a.
    what is that far, why does it have a clamp on it???
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: Boost BYpass Valve capped Off?????
    Appleton, Wi
    Quote Originally Posted by blowfishRus6 View Post
    WOW 1st reply and already getting messed with? 3361 posts BLOWFISHRUS6........ you must know what Im talking about. I added Arrows for everyone
  4. #4 Re: Boost BYpass Valve capped Off?????
    Feb 2008
    San Diego, CA
    The clamp thingy originally held a small foam filter.
    Yeah, that nipple has to be open to atmosphere for the BBV to work correctly.
  5. #5 Re: Boost BYpass Valve capped Off?????
    Joliet, IL
    if you have a cam and a 3.2 and arent scanning for knock on the daily with a aero or your choice thats just silly IMO....you were prob knocking like MF or still are if you running 14's on that setup....
    i ripped out that hose also and put a L fitting on the FPR and unplugged the Boost Bypass Solenoid and removed all the vac line you will need to delete a code if you dont want a CEL but it is completely fine to do this i have had no issues....
    either your knocking or cant launch your car because i have a buddy running a 13.6 on mods simliar to mine...and my est. 1/4 is a 13.8 so something is def not right...
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  6. #6 Re: Boost BYpass Valve capped Off?????
    g.a.
    [QUOTE=agrazela;253464]The clamp thingy originally held a small foam filter.
    QUOTE]
    thats more or what i was getting at....
    but thanks for the arrows
    its slow.
  7. #7 Re: Boost BYpass Valve capped Off?????
    HUDSON
    I had the same problem only the large wire harness that is right there was pressing against so hard it was blocking that port, and the foam thingy was mangled. So all I did was clean it off and put a little rubbber 90 degree fitting on it pointing down to help keep dirt out. And your right, A WHOLE NUTHER ANIMAL!!!!
    Dean
  8. #8 Re: Boost BYpass Valve capped Off?????
    So wait...you put a 90* bend on the BBV AFTER you got it running right? Sorry if you didn't...got lost in thought and it is still early lol
  9. #9 Re: Boost BYpass Valve capped Off?????
    who seriously has their BBV hooked up correctly anyway? its a waste of time.
  10. #10 Re: Boost BYpass Valve capped Off?????
    Appleton, Wi
    Quote Originally Posted by BoostJunki3 View Post
    Its not that Im knocking like a MO FO or cant launch the car?? The car was tuned with the BBV plugged/capped off So im at 0 knock. Im tuning/scanning tonight so well see what the car is really capable of.
  11. #11 Re: Boost BYpass Valve capped Off?????
    Banned - Busted For Scamming
    Feb 2009
    I take it you dont have a boost gauge then or you would have found the problem already
  12. #12 Re: Boost BYpass Valve capped Off?????
    Jan 1970
    Maquoketa, Iowa
    You could have been only hitting 5psi max at the time you ran. Given you had a 3.2" pulley on it taking away that extra power, 14's sound about right.
  13. #13 Re: Boost BYpass Valve capped Off?????
    Oct 2008
    Northern Illinois
    With a cam and a 3.2 if it's done right and you're not knocking you should be in the 12s...
  14. #14 Re: Boost BYpass Valve capped Off?????
    Appleton, Wi
    Quote Originally Posted by BwolfGT View Post
    Thats what all the GP guys at the track were saying yet not one noticed my BBV capped off
    I started to re-tuned today with my buddy. I'm at 18* of timing and just a blip of KNOCK above 5200. Ran outta time today but should be knock free by tomorrow. I think im gonna drop to a 3.0 pulley as well.
  15. #15 Re: Boost BYpass Valve capped Off?????
    I say leave that pulley and keep cranking the timing.
  16. #16 Re: Boost BYpass Valve capped Off?????
    Charles City, IA
    Try running more timing on the 3.2
    SMGPFC Two Nipple General
  17. #17 Re: Boost BYpass Valve capped Off?????
    i agree with more timing. the car will feel like it runs better that way as well.
  18. #18 Re: Boost BYpass Valve capped Off?????
    Appleton, Wi
    Like how much more?? 19*-20* I dont want to start floating any heads. A local guy with a similar setup as mine but with a SSIC tried 22* and floated his heads.
  19. #19 Re: Boost BYpass Valve capped Off?????
    Jan 1970
    Maquoketa, Iowa
    I tuned a S1X cammed genV regal that ran 12.8's all day in the 1/4 on stock timing tables and a 3.3 pulley. It will vary from car to car, but I agree with running a 3.2 and up the timing. Do you have 42# inj?
  20. #20 Re: Boost BYpass Valve capped Off?????
    if it were me i would personally stop at 18* and go for more boost then just because that how i like to run my cars, but timing is free power and you have to take advantage of it while you can.
  1. m90 bypass valve question
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2009, 04:44 PM
  2. Boost Bypass Valve Questions....
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 08:25 AM
  3. Boost Bypass mod
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-30-2008, 11:49 AM
  4. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
