I'll start out with the basics.
Changed the plugs out. Car had Iridiums in it and it felt like there was a miss at idle in gear. Put some plugs in it, not sure the brand off hand.
After that, the car now misses. But it only misses when it hits boost or if it's in idle in gear only. If it's idleing en park or just basic driving, anything without a load on it, no miss.
So I checked around since no code was thrown. Changed the wires, pulled the plugs and gapped them to (O'Reillys said .60), nothing fixed it. So I braked it up the road to keep it skipping and it finally threw a code. Cylinder 6 misfire. I put a coil on it, no change. Changed the fuel filter, no change.
I looked in another thread on here before posting and saw the AL104's gapped to .50. Bout to go down to the store and get some of those and try that.
After all the other things, now when I am going up a hill, I get it wanting to hesitate and i'm getting valve rattle. Sounds like sound you used to hear on the old Shell commercials when you didn't get good gas, the old valve clatter.
Any other things I might check on this? Any help would be appreciated.
Thanks.
