Thread: Cylinder 6 misfire with a p0102
Results 1 to 3 of 3
  1. #1 Cylinder 6 misfire with a p0102
    SE Level Member icolex1's Avatar
    Feb 2009
    Highspire,PA
    I have an '02 GP gt , I did the LIM ( thanks to dubobs vid) and the front head gasket here a couple months ago. replaced wires plugs, plenum, ect.
    I did not pull the back head off . I have been getting a a backfire-pop when I stomp on it , its hesitates, ect. I took it to a garage and had it put on a machine, mechanic said try replaceing the coil pack for 6, I did that and power seemed to improve, until a couple days later,
    I'm kinda out of idea at this point, I have switched injectors and injecter wires and still keep getting this cylinder 6 misfire, is it possible for the front cylinder to be poping and for some stupid reason the computer read it as a cyl 6? At least if that were possible then I would pull the valve covers off and re-check the torque on the rocker arms?
    Any ideas guys??
    BOUNCE them off me !!!!!!! Thanks!
    hydro-powered
  2. #2 Re: Cylinder 6 misfire with a p0102
    SE Level Member beast3300's Avatar
    Cat converter might be clogged. Does it run better if you unplug the MAF sensor?
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
  3. #3 Re: Cylinder 6 misfire with a p0102
    The bad MAF would make the car die, not misfire...at least not a random one.
    How does the plug look? Replace the wire? Maybe it got damaged? Also, check the ICM. That might be the issue you might have to replace that...
  1. 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    By srlash in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 10:00 PM
  2. Random multiple cylinder misfire
    By sunfiregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 08:58 PM
  3. All Cylinder Misfire after LIM Change and Vac Leak?
    By Lawngoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2009, 06:32 PM
  4. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
  5. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
