Thread: Advice on shuddering/vibration @ 45 mph
Results 1 to 18 of 18
  1. #1 Advice on shuddering/vibration @ 45 mph
    SE Level Member sportz's Avatar
    columbus, oh
    I've been trying to figure out what could be causing my 97 GT, with 132,000 miles on it, to shudder/vibrate when I hit about 45 mph. It feels like the whole car is shaking and it's driving me nuts. It's only just cropped up in the last couple of months.
    I first thought it was wheel/tire related. To that end, I've replaced, tires, LCAs wheel bearings, rotors. That's just this year. Last year it was struts, tie rod ends.
    After a little research, I'm thinking it may be some transmission problem but, the car shifts fine. I'm planning on changing the fluid/filter this weekend though. The problem occurs on all road conditions. It just starts at 45 and can be a quite severe bouncing/shaking but then goes away when I hit 50 mph.
    If anyone has any ideas as to what the problem may be, or how to diagnose it, please chime in.
  2. #2 Re: Advice on shuddering/vibration @ 45 mph
    Wausau, WI
    I didnt know there was much in the transmission that could really vibrate. Usually the transmission is broke or it works fine. Have you checked your CV axles/shafts? They could vibrate too........just a thought.
  3. #3 Re: Advice on shuddering/vibration @ 45 mph
    columbus, oh
    I'm more inclined to think it's something to do with the tires really. I'm going to get them re-balanced Friday. I made a quick check or two driving home today and it's gotta be something there. The transmission didn't seem to have any effect on the vibration I was getting today.
  4. #4 Re: Advice on shuddering/vibration @ 45 mph
    nothing in the transmission will cause a vibration. its more than likely the axles or the tires.
  5. #5 Re: Advice on shuddering/vibration @ 45 mph
    Wausau, WI
    I was thinking tires in the first place, but you said that they had been balanced
    Your tires might be f'ed or just need to be re balanced
  6. #6 Re: Advice on shuddering/vibration @ 45 mph
    columbus, oh
    That's what I'm thinking. does anyone know how to test if the half shafts need replacing? At the moment, they look good (boot wise) and they don't make any noises.
    Meanwhile, it's off to the tire place again tomorrow for another re balance.
  7. #7 Re: Advice on shuddering/vibration @ 45 mph
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    I guess you've never had an input shaft go bad....
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  8. #8 Re: Advice on shuddering/vibration @ 45 mph
    Quote Originally Posted by sportz View Post
    Could be tires - could be input shaft - could be warped/bent rim - could be could be could be.
    First thing to look for when you think a halfshaft might be a problem - grease. Check inside the wheel wells for any grease on the control arm - and on the sway bar - it tends to accumulate on the outermost sway bar bushing. Half shafts tend to "let you know" when they are going out - you will either have a noticeable noise when turning corners, or even when just cruising down the highway. In corners, you'll hear a sort of "wharble" - sounds like something is out of round, and is often accompanied by tire squealing - on the highway it will sound like a growling noise - almost like excessive road noise. You may want to check the tie rods as well - jack the car up, grab the tire and 3 and 9 o'clock and try to move it left to right, do the same at 12 and 6 o'clock. If it moves much at all - that could be your culprit- and yes it can/will cause vibrations.
    If you check those and all is well - or don't have any of those other symptoms...get the tires/wheels balanced - make sure to have them tell you what corrections they made and where. If that still doesn't fix it - I would recommend pulling the driver's side halfshaft and checking the input shaft on the transmission - if it starts puking fluid as soon as you pull the halfshaft off - and the input shaft is loose - there is your problem...and I'm sorry. At that point - call Trannyman.
    -Swash
  9. #9 Re: Advice on shuddering/vibration @ 45 mph
    Donating Users chrisb's Avatar
    Bucyrus, OH
    umm ok?
    i doubt its this but lockup on the torque converter happens between 45 and 50 normally.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  10. #10 Re: Advice on shuddering/vibration @ 45 mph
    columbus, oh
    Quote Originally Posted by Swash View Post
    -Swash
    I've checked the half shaft boots and they are clean. I can't tell if they are loose or anything. Like I said, they don't make any noise so I think they may be ok. I had the tires rebalanced today and it helped a lot. Although, there is still some vibration. The guy said he matched up the high spots on the rim with the tires and checked to see if my lateral runout on the rims was ok. All checked out.
    I'm still pretty much stumped really. I could go for one more balance but I'm pretty skeptical if it will solve the problem. Maybe a half shaft replacement is in order. Or, I was thinking maybe it might be the rear rotors. I replaced the front two but the rears haven't been messed with. I've run out of money to mess with it really but at this point all that's left that hasn't been replaced are the half shafts and rear rotors.
    Thanks for all the feedback everyone.
  11. #11 Re: Advice on shuddering/vibration @ 45 mph
    Wausau, WI
    is there any way you can get your hands on different rims and tires just to put them on and see if any difference is made? If balancing them helped the problem, maybe it is just in the rims/tires. I dont know how your rear rotors would be affecting this issue. If you can wait to see what happens do that, there is no point in replacing expensive half shafts if you are not sure that those are the problem...
  12. #12 Re: Advice on shuddering/vibration @ 45 mph
    GT Level Member skidoojames151's Avatar
    seattle
    yea even if the tire/wheel is perfectly balanced...a bent rim will still cause a vibration as this was a problem on my vette and i tried tires and balancing and alignments...but it was a bent rim
  13. #13 Re: Advice on shuddering/vibration @ 45 mph
    columbus, oh
    The rims checked out fine for straightness. I'm still kind of leaning toward the rotors on the rear. I don't see how they could be that much of an issue but I'm getting really tired of going back and forth to the tire place.
    Oh, and if anyone else needs any tips on car repair and diagnosis, I found this site ( Auto Repair Articles ) that has some good articles on all kinds of stuff.
  14. #14 Re: Advice on shuddering/vibration @ 45 mph
    Detroit MI
    i got the same problem but it goes away when i accelerate and gets worse when i brake
  15. #15 Re: Advice on shuddering/vibration @ 45 mph
    Oct 2008
    Northern Illinois
    Bent/warped rim or unevenly worn tires.
  16. #16 Re: Advice on shuddering/vibration @ 45 mph
    CT
    You can always swap rims and tires front to back so you can see if a rim is the issue. The position the vibration is coming from will let you know weather tires and rims are the issue.
  17. #17 Re: Advice on shuddering/vibration @ 45 mph
    Wausau, WI
    is this resolved?
  18. #18 Re: Advice on shuddering/vibration @ 45 mph
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    does the steering wheel look like it shakes side to side, if it does its deffinitly not a bent rim, i had the same problem with my car ended up needing new bearings, tierods, and cv Axel.
  1. trans. shuddering issue
    By monte0 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2009, 08:21 PM
  2. Odd Vibration
    By VGPGT in forum General Tech Discussion
    Last Post: 04-15-2009, 04:18 PM
  3. vibration
    By david hagaman in forum General Tech Discussion
    Last Post: 04-11-2009, 11:16 AM
  4. BAH! Was Shifting hard....now shuddering
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-29-2009, 01:24 AM
  5. vibration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:24 AM
