Quote Originally Posted by sportz View Post
That's what I'm thinking. does anyone know how to test if the half shafts need replacing? At the moment, they look good (boot wise) and they don't make any noises.
Meanwhile, it's off to the tire place again tomorrow for another re balance.
Could be tires - could be input shaft - could be warped/bent rim - could be could be could be.
First thing to look for when you think a halfshaft might be a problem - grease. Check inside the wheel wells for any grease on the control arm - and on the sway bar - it tends to accumulate on the outermost sway bar bushing. Half shafts tend to "let you know" when they are going out - you will either have a noticeable noise when turning corners, or even when just cruising down the highway. In corners, you'll hear a sort of "wharble" - sounds like something is out of round, and is often accompanied by tire squealing - on the highway it will sound like a growling noise - almost like excessive road noise. You may want to check the tie rods as well - jack the car up, grab the tire and 3 and 9 o'clock and try to move it left to right, do the same at 12 and 6 o'clock. If it moves much at all - that could be your culprit- and yes it can/will cause vibrations.
If you check those and all is well - or don't have any of those other symptoms...get the tires/wheels balanced - make sure to have them tell you what corrections they made and where. If that still doesn't fix it - I would recommend pulling the driver's side halfshaft and checking the input shaft on the transmission - if it starts puking fluid as soon as you pull the halfshaft off - and the input shaft is loose - there is your problem...and I'm sorry. At that point - call Trannyman.
-Swash
