Thread: HID problems...Looking for answers
Results 1 to 20 of 41
  1. #1 HID problems...Looking for answers
    St. Louis Mo.
    Ok here is my problem. I received my WBody HID kit from the Branson GPM and I just recently installed them, about 3 months ago, and ever since then I have had problems with them.
    Originally when they were first installed, I just used the harness that Wbody provided that connected to the factory plug on the lights then connected to the ballast of the HIDs. Whenever I would turn on the lights, either the left or right HID would not want to come on. I would have to flick the high beams to get the ballasts to start up. This has been a constant problem since I have had them installed.
    Just a week ago I got a new wiring harness for the HIDs to run independently from the stock wiring and work solely off the battery for direct power to help correct the problem as many have suggested would fix it. However even after installing the wiring harness the problem still persists. It is not as severe as before the wiring harness was installed but it is still going on. Also I find at times the right side HID flickering from time to time. It is very annoying.
    The new setup is as follows. The new wiring harness is connected to the battery, it’s a has a nice big HID relay switch that feeds to lines that go to the power for both ballasts and one plug that plugs into the aftermarket harness that WBody provided. All grounds are good and the lights are working, but not as intended I am sure due to the problem listed above. I am only using one of the aftermarket harness' that WBody provided to plug in from the passanger light assembly into the new HID Wiring Harness that then plugs into the ballast on the right side. The driver side wiring of the HID wiring harness plugs directly into the ballast, no WBody aftermarket wiring harness used on that side of the assembly.
    I know Chris, Webracin, had created a little device that was supposed to delay the HIDs from activating, but I never heard anything else about it. I sent him a PM or two on the National Boards back in the days before all the fallout there.
    Does anyone have any suggestions on what might be the “fix” to this problem or suggestions to help correct it? Or could it be a problem with the ballasts themselves? The ballasts from WBody are pure chrome looking and do not have any labels at all on them. I could not even determine who the maker would even be of them.
    Many thanks for reading all of this.
    James Shafer
    St. Louis MO
  2. #2 Re: HID problems...Looking for answers
    Banned
    New Port Richey Florida
    Hmmm i'd say you got your self a bad ballast..
  3. #3 Re: HID problems...Looking for answers
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Sounds like you have ballast that is dead or dying. What sucks about no name brands. They are hit and miss. Other issue could be the harness itself. Where did you get the harness at or did you make it?
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: HID problems...Looking for answers
    GrandPrix Junkie
    Saraland Alabama
    It being both sides, ballast doesn't make sense unless both ballasts are bad
  5. #5 Re: HID problems...Looking for answers
    Oklahoma
    Geddy I sent a message to Chris for you, he says he has some switches left if you want one. But Id wait for him to see if he posts in here and gives his input on the issue you are having. He knows way more about HIDs than I do because he has them.
  6. #6 Re: HID problems...Looking for answers
    GTX Level Member 02BlueGT's Avatar
    Hoffman/Schaumburg, IL
    could this be a ground issue, cause you fixed the power side, did the ground side get any attention
    2002 GT...CAI, Headers, Special Eddition two-tone leather interior added, HUD added, 12" Brake Upgrade, ZZP strut tower bars, gmpp sway bars, poly motor mounts, -6an braided SS fuel hoses , Hptuned, Headers, Top Swaped, 50lb inj, E85, 3.4
    I've got Boost!! Top swap Quesions? Click Here
  7. #7 Re: HID problems...Looking for answers
    Tulsa, Ok
    Hoe exactly is the relay wired up?
    98' GS - Sold
  8. #8 Re: HID problems...Looking for answers
    GT Level Member BackInBlack's Avatar
    Vermont
    Is that just a 9007-1 kit? What do you have your +12 high beam feed tied to? You don't need an upgraded harness for that kit. Most ballasts will operate down to 9-10VDC, which unless you have a dead battery, will not happen at the headlamp sockets. Try powering up a ballast and bulb outside the car with some (fused protected) jumper wires to the battery (+12 lug at top of relay center will do). The only time you need a harness, is if the kit is a tilting or telescopic type, and generally they come with it because of the relay logic module.
    I have lots of info here:
    ClubGP Message Forum troubleshooting
    The GPs are long gone...
  9. #9 Re: HID problems...Looking for answers
    St. Louis Mo.
    Here is the link to the Wiring harness I purchased for my HIDs.
    eBay Motors: HID fuse relay wiring harness 9005 9007 9006 H1 H3 H4 (item 120218211703 end time Feb-09-08 14:15:56 PST)
    Here is a brief description of the harness....
    Features and Benefits
    MAXIMUM OF 50W POWER SUPPORT!
    5 WIRES AND 1 FUSE DESIGN
    BLACK NEGATIVE WIRE; RED POSITIVE WIRE
    CONNECTOR TO OEM SOCKET WHICH ALLOWS THE THE HID TO TURN ON AND OFF WITH THE CONTROL OF THE VEHICLE'S LIGHT SWITCH
    2x HID BULB CONNECTOR WIRES
    DRAWS POWER FROM THE BATTERY; NOT THE VEHICLE'S ELECTRICAL SYSTEM; GUARANTEED NOT TO SHORT YOUR VEHICLE
    POLY SYNTHETIC WIRE COVER TO PREVENT DAMAGE FROM EXCESSIVE HEAT CAUSED BY THE ENGINE
    E-MARK AND CE APPROVED
    EXTRA LONG WIRES AND WIRE TIES FOR A CLEAN INSTALLATION & LOOK!
    The way the HIDs are hooked is through the Wiring harness off the Battery. The lines from down the passanger side past the battery and then relay is located there with three wires leading from it. One of blue aftermarkter connections that connects to the actual headlamp is now plugged into the conection on the wiring harness to provide the power connecting back to the relay which inturns powers the 2 lines leading to the ballasts.
    The blue wire in the picture above in my first post, is only used on the passanger side of the car. And other ballast has the direct power connection from the harness.
    I am personally thinking it is the ballasts. I know the Ground connection of the new relay is spotless, cause IF it was not? The lights would not even come on at all. I feel the problem involves the ballasts only.
    I can try and scare up some photos of the new wiring harness if need to be. And in regards to your question BlackinBlack. I am not sure if it is connected the way you mentioned. As I said before. The wiring with the blue ends, in the above photo, are connected the lamps connection of the same type connection for the 9007 bulbs.
    I hope I am explaining this right?
    And to answer your other question Black. These are single bulb HIDs no duals or extending HIDs. Sorry forgot to add that.
    James Shafer
    St. Louis MO
  10. #10 Re: HID problems...Looking for answers
    GTX Level Member webracin's Avatar
    Arkansas
    Hey Geddy,
    I still have 2 of the kits I made up available. They really dont address the one light on issue, but since I installed the delay, it is few and far between when I have the issue now.
    All the kit is, is a delay to allow the car to start before the headlights come on, which most say will save the ballast.
    I have had mine installed for quite a while now and have the one light on issue maybe once a week, where before it was once a day.
    Ground is not the issue either because I have the harness which also runs a seperate ground and is powered thru relays off the battery and the issue still occurs.
    If you want to give the relay a shot, its posted in the for sale section.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  11. #11 Re: HID problems...Looking for answers
    GrandPrix Junkie
    Saraland Alabama
    really that sounds like just plain shoddy workmanship
  12. #12 Re: HID problems...Looking for answers
    St. Louis Mo.
    Quote Originally Posted by archemedes View Post
    I would tend to agree with that statement. I know Chris probably has the same ballasts as I do. And he too is still experiencing the same issue. Not sure how I should go about approaching WBody on this issue, without ruffling any feathers.
    James Shafer
    St. Louis MO
  13. #13 Re: HID problems...Looking for answers
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by GeddyLee View Post
    Oh me me, let me ruffle feathers.
    fwiw...Mike has always been really great to deal with.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  14. #14 Re: HID problems...Looking for answers
    St. Louis Mo.
    Quote Originally Posted by IndeedSS View Post
    As long as I dont run into Justin. I have not had much luck with that guy for sure!!! But YES Mike is good people to deal with!
    I want to try the fuse swap this weekend and see what happens. After I will goto Mike and try and tastefully explain the situation And if all else fails? I will drag you into it Lee
    James Shafer
    St. Louis MO
  15. #15 Re: HID problems...Looking for answers
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    are the fuses the mini plug in or just the regular sized ato plugin? there are extra mini plug in fuses in the underhood fuse box... should be a 15 in there...
  16. #16 Re: HID problems...Looking for answers
    Vermont
    What happens when you just plain plug the ballasts into the stock headlamp bulb harness?
  17. #17 Re: HID problems...Looking for answers
    St. Louis Mo.
    Quote Originally Posted by BackInBlack View Post
    Well i have to use those blue connectors in the picture on the first page to make the connection between the headlamps and the Ballasts. But that was the setup I was using at first and the problems with the headlights coming on or half of them coming on started immediatedly when I first installed them.
    And there has not been night before I got this wiring harness, that both lights would actually light up at the same time. I would have to flick the highbeam switch a couple of times to coax the other one to turn on.
    After hooking up the wiring harness, I have had more like 60/40 chance now of BOTH HIDs coming on at the same time. It is an improvement of the prior setup, but not by much.
    I hope that better explains it for you Black?
    James Shafer
    St. Louis MO
  18. #18 Re: HID problems...Looking for answers
    GrandPrix Junkie
    Saraland Alabama
    sounds like a flourescent light when it's too cold
  19. #19 Re: HID problems...Looking for answers
    St. Louis Mo.
    I was kinda wondering that same thing, but when I installed them back in October, the weather was still quite warm and they were doing it then.
    James Shafer
    St. Louis MO
  20. #20 Re: HID problems...Looking for answers
    Arkansas
    Same here, I installed them when the weather was still in the 80's...mine has improved to about 85/15 (new harness and delay switch).
    The only thing I can think of that even remotely makes sense is the initial current draw of the ballast. With both coming on at the same time, it may be tripping one of them. I may have to try something like delaying one of the lights so that they come one one at a time and see if that works, but that wont be for a while....the ice storm is here this weekend, so I can deal with it for now, but I would like to find a fix.
    webracin
    2001 Grand Prix GTP
  1. Fuel Gauge Problems
    By thermanlee in forum General Tech Discussion
    Last Post: 05-29-2008, 12:33 PM
  2. starting problems
    By redgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 12:24 AM
  3. Starting Problems
    By SahotaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2008, 01:38 AM
  4. No fire on #3 cyl, injector problems??
    By gplostinnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 12:28 AM
  5. Trans problems.
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 07:24 AM
