Here is the link to the Wiring harness I purchased for my HIDs.
eBay Motors: HID fuse relay wiring harness 9005 9007 9006 H1 H3 H4 (item 120218211703 end time Feb-09-08 14:15:56 PST)
Here is a brief description of the harness....
Features and Benefits
MAXIMUM OF 50W POWER SUPPORT!
5 WIRES AND 1 FUSE DESIGN
BLACK NEGATIVE WIRE; RED POSITIVE WIRE
CONNECTOR TO OEM SOCKET WHICH ALLOWS THE THE HID TO TURN ON AND OFF WITH THE CONTROL OF THE VEHICLE'S LIGHT SWITCH
2x HID BULB CONNECTOR WIRES
DRAWS POWER FROM THE BATTERY; NOT THE VEHICLE'S ELECTRICAL SYSTEM; GUARANTEED NOT TO SHORT YOUR VEHICLE
POLY SYNTHETIC WIRE COVER TO PREVENT DAMAGE FROM EXCESSIVE HEAT CAUSED BY THE ENGINE
E-MARK AND CE APPROVED
EXTRA LONG WIRES AND WIRE TIES FOR A CLEAN INSTALLATION & LOOK!
The way the HIDs are hooked is through the Wiring harness off the Battery. The lines from down the passanger side past the battery and then relay is located there with three wires leading from it. One of blue aftermarkter connections that connects to the actual headlamp is now plugged into the conection on the wiring harness to provide the power connecting back to the relay which inturns powers the 2 lines leading to the ballasts.
The blue wire in the picture above in my first post, is only used on the passanger side of the car. And other ballast has the direct power connection from the harness.
I am personally thinking it is the ballasts. I know the Ground connection of the new relay is spotless, cause IF it was not? The lights would not even come on at all. I feel the problem involves the ballasts only.
I can try and scare up some photos of the new wiring harness if need to be. And in regards to your question BlackinBlack. I am not sure if it is connected the way you mentioned. As I said before. The wiring with the blue ends, in the above photo, are connected the lamps connection of the same type connection for the 9007 bulbs.
I hope I am explaining this right?
And to answer your other question Black. These are single bulb HIDs no duals or extending HIDs. Sorry forgot to add that.
