Thread: HID problems...Looking for answers
Results 1 to 20 of 41
  1. #1 Re: HID problems...Looking for answers
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by GeddyLee View Post
    I would tend to agree with that statement. I know Chris probably has the same ballasts as I do. And he too is still experiencing the same issue. Not sure how I should go about approaching WBody on this issue, without ruffling any feathers.
    Oh me me, let me ruffle feathers.
    fwiw...Mike has always been really great to deal with.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: HID problems...Looking for answers
    St. Louis Mo.
    Quote Originally Posted by IndeedSS View Post
    As long as I dont run into Justin. I have not had much luck with that guy for sure!!! But YES Mike is good people to deal with!
    I want to try the fuse swap this weekend and see what happens. After I will goto Mike and try and tastefully explain the situation And if all else fails? I will drag you into it Lee
    James Shafer
    St. Louis MO
  3. #3 Re: HID problems...Looking for answers
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    are the fuses the mini plug in or just the regular sized ato plugin? there are extra mini plug in fuses in the underhood fuse box... should be a 15 in there...
  4. #4 Re: HID problems...Looking for answers
    St. Louis Mo.
    Quote Originally Posted by Toasty View Post
    They are your run of the mill regular sized Fuses, not the little mini fuses, at least from what I can tell. I am gonna out tomorrow and do more of a close up inspection and then hit Autostoned or O'Riellys to get some extra 15s. I need some anyways. I cant find my old stach I use to have of them. So I guess it's time to restock
    James Shafer
    St. Louis MO
  5. #5 Re: HID problems...Looking for answers
    St. Louis Mo.
    For those wanting to know the set up I have. Here are pictures to be see my setup for my HIDs.
    An overview shot, showing the HID harness connected the fuse box.
    The 10amp fuse on the Wiring Harness of the HIDs.
    A side view of the relay of the HID Wiring Harness..
    A front picture of the HID Relay. Sorry for the bluriness of it.
    This is an overview shot of the HIDs connecting to the Headlamp and the relay line connecting to the HID wiring harness...
    A close up of the relay line from the HIDs to the Wiring Harness. And you can see the relay line has a 10amp fuse on it leading to the Wiring the Harness.
    A picture of the Wiring harness connecting to the ballast on the passanger side using the Wiring Harness's power connection...
    The driver side only had the Wiring Harness's power line running directly into the Ballast. There is no relay wire like on the passanger side.
    I hope this gives a better idea of what I am trying to discribe. Thanks again for looking!!
    James Shafer
    St. Louis MO
  1. Fuel Gauge Problems
    By thermanlee in forum General Tech Discussion
    Last Post: 05-29-2008, 12:33 PM
  2. starting problems
    By redgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 12:24 AM
  3. Starting Problems
    By SahotaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2008, 01:38 AM
  4. No fire on #3 cyl, injector problems??
    By gplostinnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 12:28 AM
  5. Trans problems.
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 07:24 AM
