Hey Geddy....Any luck yet? Did the switch arrive? You know in the last week, I have paid close attention to when I start the car. It has worked perfectly. If you have not installed the switch yet, try this first.
When I start my car, I put the key in and roll it right to start (this is where on the odd occasion the drivers side light would not lite up).
For the last week, I have put the key in, turned it to on and waited about a second, then went to start, and every time its worked fine. I don't know if its the switch or if its the way I started the car.
I can tell you this. That switch will work every time, however I noticed when I was setting the delay on all the ones I shipped out that if the trigger comes in to start the delay, IF there is another trigger within the 5 sec (which is how long I set the switch to keep the lights off) it can cause the switch to turn on the lights prematurely.
So basically here is the deal...
The headlights on signal triggers the delay switch, and the switch will kill power to the headlights for 5 seconds (or whatever you set it to).
If another headlights on signal comes in at say 3 sec, every once and a while it will over ride the switch and cause it to turn the lights on. Will this hurt anything....No not at all, its just an explanation of what could happen maybe 1 out of 100 times.
The reason I set it to a 5 sec delay is because by the time I hit the remote to unlock the door, get in the car and get the key in, its about 5 sec. I then go to start the car and let it warm up a bit (usually way more than 5 sec) the lights are on when I am ready to go.
If you have any questions about the install, feel free to ask
webracin
