Pulled from Intense's site.
LGVS-LS6 Specifications:
  • Installed load is 90 pounds at 1.800", 115 pounds at 1.720", and 300 pounds at 1.230".
  • Coil bind height is 1.160".
  • Outside diameter is 1.290"/1.060" and inside diameter is .885"/.656".
  • Maximum lift supported @ 1.720" (stock retainer install height) - .500"
  • Maximum lift supported @ 1.800" (Manley retainer install height)- .580"
VSS-105 Specifications:
  • Installed load is 105 pounds at 1.800", 127 pounds at 1.720", and 293 pounds at 1.200".
  • Coil bind height is 1.125".
  • Maximum lift supported @ 1.72 (stock retainer install height) - .595"
  • Maximum lift supported @ 1.80 (Manley retainer install height) - .675”
VSS-130 Specifications:
  • Installed load is 130 pounds at 1.800", 150 pounds at 1.720", and 318 pounds at 1.200".
  • Coil bind height is 1.080".
  • Maximum lift supported @ 1.72 (stock retainer install height) - .640"
  • Maximum lift supported @ 1.80 (Manley retainer install height) - .720"
