Thread: rollers or modified.
Results 1 to 20 of 39
  1. #1 Re: rollers or modified.
    TDCRacing
    Guest
    Might as well market off a 3.25:1 Roller Rocker Parker...make that bastard open so far the valve falls out LMAO!!
    I'm on it...
  2. #2 Re: rollers or modified.
    GT Level Member 05SS45's Avatar
    Jan 2009
    westport maSS
    so no price's or place's to get L76 springs lol!
    Going back to stock *GRANT built trans BLOWN w/17k*
  3. #3 Re: rollers or modified.
    It's a GM spring, that's cheap and readily available at dealerships from what I've heard on the street.
    Another low cost choice is looking to ebay for LS6 springs. Usually there is a set or two going very cheap. Only thing there is you shouldn't use them on a 96 or 97 head because of the shape.
  4. #4 Re: rollers or modified.
    Jan 2009
    westport maSS
    cool thaks bill! do the LS6 springs have a diff max lift rate?
  5. #5 Re: rollers or modified.
    Pulled from Intense's site.
    LGVS-LS6 Specifications:
    • Installed load is 90 pounds at 1.800", 115 pounds at 1.720", and 300 pounds at 1.230".
    • Coil bind height is 1.160".
    • Outside diameter is 1.290"/1.060" and inside diameter is .885"/.656".
    • Maximum lift supported @ 1.720" (stock retainer install height) - .500"
    • Maximum lift supported @ 1.800" (Manley retainer install height)- .580"
    VSS-105 Specifications:
    • Installed load is 105 pounds at 1.800", 127 pounds at 1.720", and 293 pounds at 1.200".
    • Coil bind height is 1.125".
    • Maximum lift supported @ 1.72 (stock retainer install height) - .595"
    • Maximum lift supported @ 1.80 (Manley retainer install height) - .675”
    VSS-130 Specifications:
    • Installed load is 130 pounds at 1.800", 150 pounds at 1.720", and 318 pounds at 1.200".
    • Coil bind height is 1.080".
    • Maximum lift supported @ 1.72 (stock retainer install height) - .640"
    • Maximum lift supported @ 1.80 (Manley retainer install height) - .720"
  6. #6 Re: rollers or modified.
    And some L76 info, quoted from RegalGS and other sites.
    The L76/L92 valve spring. Part # 12589774. With a GM list price of $3.59 each. (Pace Perf, $2.59)They have the same 90# seat pressure as the yellow LS6 spring, but a lower spring rate. LS6 are 375#/in. L92 are 348#/in. The Comp Cams 105# springs have a spring rate of 313#/in.
    These springs actually cost less than our stock springs.
    The valve spring specs for the GM springs are on page 281 of the 2008 GM Performance Parts Catalog. The L92 spring does have a limit of .530 lift so it is for rockers and mild cams, like the VS. By my calculations, at .500" lift the L92 and the 105# Comp cams are within 3 or 4 lbs in total pressure. This is a lower cost set up that should lower the wear compared to the LS6.
    From the GMPP catalog 12589774
    Valve Springs
    • Beehive style springs
    • Standard L76/L92 springs
    • 1.800" installed height @ 90# pressure
    • 1.300" @ 264# pressure
    • Max lift .530"
  7. #7 Re: rollers or modified.
    Jersey
    Quote Originally Posted by 05SS45 View Post
    Oops sry man . I just decided to re-visit this thread. I think i paid $80 for mine, i got them from the dealer. If i were to do it again, i would buy from Pace, there prices are pretty good.
    16' wrx sti- stock
  8. #8 Re: rollers or modified.
    Oxon Hill, MD
    FWIW, I just found my receipt for my L76 springs. About $32 from ZSPOT on NAIOA.com. So, 05SS45, if you're looking for springs, I'd contact ZSPOT no matter what spring you go with.
  9. #9 Re: rollers or modified.
    Jan 2009
    westport maSS
    Quote Originally Posted by whitelightnin04MC View Post
    o sweet whitelightnin thanx dude!
  10. #10 Re: rollers or modified.
    GT Level Member Xorbex's Avatar
    Canada
    Do I have to pull the motor on an 05 to install a cam. Thats the only reason I would use rockers instead.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  1. My modified headlight!!
    By Malefic_GP in forum General Tech Discussion
    Last Post: 09-27-2008, 11:27 PM
  2. Modified '97 TB?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2008, 10:57 PM
