Thread: Car tries to start but will not.
Results 1 to 9 of 9
  1. #1 Car tries to start but will not.
    allen
    2000 GTP Stock for the most part. Last night I was on my way home going about 30 mph, and my car just shut off. I stopped and it started back up, then I drove it about 1 mile and I was home. Then 2 hours later it would not run, just turn over and start for a split second. Today I started it and drove it about 15 miles without any problems, and 2 hours later it would not start again.
  2. #2 Re: Car tries to start but will not.
    Donating Users mystic231's Avatar
    Michigan
    I thinking Mass Air Flow Sensor or MAF for short. Is your "Check Engine" light on?
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  3. #3 Re: Car tries to start but will not.
    allen
    that's what it was looking like from all the threads I was reading. Ya my ses light is on. I'm gonna take it in to autozone tonight, if it starts, and gets the codes.
  4. #4 Re: Car tries to start but will not.
    Michigan
    If you need a new MAF consider NAPA. Lifetime warranty with receipt. My last Autozone MAF lasted one year. ALL MAF's from these parts stores are re-builds (that's why they want your core) so having it last only a year wasn't surprising. But if You can get the same part for roughly the same price with a lifetime warranty...
    '02 Bright Red GT
  5. #5 Re: Car tries to start but will not.
    allen
    Took it to autozone and the only code that came up was the ox censor. Guy there had the same problem and it was his fuel pump. And now my car won't start again . Any reason why anyone thinks it wouldn't be the fuel pump?
  6. #6 Re: Car tries to start but will not.
    Jan 1970
    Maquoketa, Iowa
    A trouble code won't come up for a failed maf. Unplug the maf and see if it changes anything.
    As far as fuel pump can you hear it come on/off when you turn the key, especially after the car dies? Next time it dies, leave the key forward, pop the hood and take the plastic cap off the fuel rail and depress the valve in there to see if fuel comes out.
  7. #7 Re: Car tries to start but will not.
    Houston, TX for now
    Quote Originally Posted by FoSHO99 View Post
    Also it should not only come out but come out with some pressure. My car was doing the same thing and the fuel pump was only working part of the time. I didn't think it could be the fuel pump because I could hear it whining but it turns out it wasn't working well enough to maintain pressure. And by the way it is also a 2000.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  8. #8 Re: Car tries to start but will not.
    allen
    its the maf. I unplugged it. my car started. plugged it back in and then 5 seconds later my car died. Thanks a lot for the help!!!
  9. #9 Re: Car tries to start but will not.
    Michigan
    Thanks for the reply. Lifetime warranty on MAF's from NAPA.
    '02 Bright Red GT
  1. where to start
    By bitterpill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 10:46 PM
  2. Where to start?
    By mminchau in forum General Tech Discussion
    Last Post: 05-31-2009, 10:51 AM
  3. Where should I start on my 07 gt?
    By 07gpgt in forum General Tech Discussion
    Last Post: 04-30-2009, 03:15 AM
  4. Help car won't start
    By gtora69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 05:48 PM
  5. Start Me Up!!!
    By coolken84 in forum General Tech Discussion
    Last Post: 02-14-2009, 01:47 PM
