Thread: 2000 GTP miss on hard acceleration
Results 1 to 3 of 3
  1. #1 2000 GTP miss on hard acceleration
    MN
    I have a problem with the car "missing" on hard accel. This happened about a year ago after I had the heads rebuilt (bad valve guides). I was driving it pretty hard, the cat converter failed probably due to the excess oil from the valve guides. I cleaned all the debris from the cat out as well as the rest of the exhaust. I'm wondering if the back pressure from the converter caused a gasket blow out. The car drives fine driving normally but if you get after it anything above 4000 rpm the engine misses, if you back off it drives fine. No engine light or other signs of major problems. The car has TOG headers and borla exhaust. Aftermarket ECM, cam, heads, accel coil packs. I haven't taken it in because I haven't driven it due to financial problems. I need to install a half shaft cv axle on the pass. side and change fluids before she's ready to take to the road. Anyone who has any thoughts please post. I'd rather not take it to a shop right now as money is tight.
  2. #2 Re: 2000 GTP miss on hard acceleration
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    you might have fried the top end driving with a bad cat can do that
  3. #3 Re: 2000 GTP miss on hard acceleration
    MN
    Thanks TurboTrav, I'll do a compression and leak down test and see where I'm at...
  1. Engine stuttering on hard acceleration
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2011, 07:09 PM
  2. 2000 GT shifting really hard
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-04-2009, 12:08 AM
  3. 2000 GTP miss on hard acceleration
    By gtp2000 in forum Introductions/Noob Questions
    Last Post: 07-26-2009, 01:06 PM
  4. I miss my car!
    By JCG's-GTP in forum Visual/Body Modifications
    Last Post: 04-15-2009, 12:55 AM
  5. I have a miss. :(
    By Doug_Guilds in forum General Tech Discussion
    Last Post: 09-09-2008, 07:19 PM
