Thread: 98 GTP dual climate control-metric?
Results 1 to 6 of 6
  1. #1 98 GTP dual climate control-metric?
    Wausau, WI
    When I bought my vehicle it came with a dual climate control which seems to work OK but it is in metric display only. I tried in the DIC to change the metric to english but only works on the DIC display. This unit has a bluish color to it, and not red. Is this the normal unit for this vehicle? Is there any way to change this to the english version?
  2. #2 Re: 98 GTP dual climate control-metric?
    Feb 2008
    I'm not sure, but it could be a Canadian car.
  3. #3 Re: 98 GTP dual climate control-metric?
    Wausau, WI
    everything else in the car is american style......dash, miles per hour, no km, etc......is it possible to change these, or am I stuck with this short of replacing the device?
  4. #4 Re: 98 GTP dual climate control-metric?
    Wausau, WI
    To the canadians or anyone else..........can anyone change theirs between metric and american???
  5. #5 Re: 98 GTP dual climate control-metric?
    SE Level Member ASCStinger's Avatar
    Jan 2009
    Rochester, NY
    if you take the climate control unit out of the dash, on the wiring harness there should be a 1 pin male and female connector that arent connected. when I was messing with mine, i found plugging them in changed from metric to american (with the key on)
  6. #6 Re: 98 GTP dual climate control-metric?
    Wausau, WI
    Quote Originally Posted by ASCStinger View Post
    I don't have time now to check this, but thanks a lot for the info........Hopefully this will work.
  1. Dual digital climate control :th_shakinghead2:
    By mikroehl in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2010, 07:26 PM
  2. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  3. will 05 dual climate control fit in an 04 gt2?
    By gp04duff in forum General Tech Discussion
    Last Post: 12-01-2008, 07:08 AM
  4. Dual climate control
    By 04gpking85 in forum General Tech Discussion
    Last Post: 10-12-2008, 11:41 PM
  5. Dual zone climate control
    By CT Tech in forum General Tech Discussion
    Last Post: 07-10-2008, 02:05 PM
