Ok I troubleshooted the car, I put the old pcv valve and worked fine, drove around and didn't get any kick backs, so I tried to put the new one again and I noticed that the old pvc valve had an o-ring (gasket I guess) replaced the pcv valve and works fine again.
I'll go again to autozone to hook up scanner, let's see if codes clears
I'll let you know guys if code is cleared
