There could be a myriad of things causing your reduced power state. That car has an electronic throttle, so in the reduced power state, it doesn't matter if you push the pedal to the floor, the blade may only partially open.
See if you can drive it to an Auto Zone or something and have the code(s) read. If not, you can borrow a scanner from them (deposit required) and return it once you're done.
