Thread: 180 T-Stat
Results 1 to 8 of 8
  1. #1 180 T-Stat
    Michigan
    I plan on doing a full flush and hose change next weekend but one thing I have not done yet is pick up a T-Stat. I was reading some info on if I were to drop in a lower temp T-stat that I would get bad gas mileage or the computer would trip codes.
    However I dont like the fact that I can fry an egg on anything under the hood after its been running. Would it be ok to grab a 180?
    Thanks!
  2. #2 Re: 180 T-Stat
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Yeah it would be fine. It won't hurt a thing. It doesn't change gas mileage at all and it deff. won't throw a code. One thing I noticed about mine was the engine temp didn't really change much with just the t stat. It took me puttin in a dhp pcm to make it stay much cooler cuz the fans came on sooner and stayed on longer. But the t stat is a cheap upgrade and u should do it while ur already in there.
  3. #3 Re: 180 T-Stat
    T-Stat won't really do anything unless you have a tune and your fan turn on point turned to 185* vs. stock. You will really only notice the temp change on the highway cruising...but it won't hurt...go ahead and throw her in there.
  4. #4 Re: 180 T-Stat
    Wausau, WI
    I have a 180 stat.......no codes and getting 27 MPG on the highway.........fwiw
  5. #5 Re: 180 T-Stat
    Quote Originally Posted by Liquifire View Post
    It's not going to really hurt your MPG to where you'll start seeing differences. Now with a 160*...maybe.
  6. #6 Re: 180 T-Stat
    Michigan
    Thanks for the replies. I have yet to go out and get a T-Stat but will by the weekend.
    You say 160, what are the pros of a 160?
    08 GXP all stock
  7. #7 Re: 180 T-Stat
    Quote Originally Posted by xerxescct View Post
    nothing besides a super cold running motor. there is no reason to run one unless you live somewhere like texas or some desert-esque hot area.
  8. #8 Re: 180 T-Stat
    Or hot lap your car at the track.
  1. 180 T-Stat
    By wykabryan in forum General Tech Discussion
    Last Post: 11-17-2008, 03:27 PM
  2. Which t-stat should I get?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 08:49 PM
  3. 180* T-stat
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 10:30 PM
  4. 180* T-stat
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2008, 06:03 PM
  5. t-stat ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-29-2008, 11:30 AM
