Thread: Which t-stat should I get?
Results 1 to 20 of 41
  1. #1 Which t-stat should I get?
    Aug 2008
    Long Island, New York
    I want to get a 180 tstat for my car, but which would be better? Intense offers one, and so does zzp. does anybody know if one is better than the other?
  2. #2 Re: Which t-stat should I get?
    Jersey
    They're all the same, I got a 180* from zzp. It works fine. You can even get one from awful zone for a few $$. U might want to replace the little rubber gasket while your at it.
    16' wrx sti- stock
  3. #3 Re: Which t-stat should I get?
    Donating Users
    W-S, NC
    I got a 180* stat and the gasket from Advance Auto for $8.
  4. #4 Re: Which t-stat should I get?
    SE Level Member black.gtp's Avatar
    Apr 2008
    Indiana
    Quote Originally Posted by 2000GTP View Post
    I went to Auto Zone and got a 160 thats what I run cost around $6
    PRJ Built enough said!!!!
    www.prjperformance.com
  5. #5 Re: Which t-stat should I get?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Ya just get one at any autoparts store. They're pretty much all the same anyway.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  6. #6 Re: Which t-stat should I get?
    get a drilled one so in case it ever fails, it will not overheat your car.
  7. #7 Re: Which t-stat should I get?
    Aug 2008
    what is the difference between a drilled tstat and a regular one? Will it perform any differently than a regular 180?
  8. #8 Re: Which t-stat should I get?
    Barksdale AFB, LA
    It'll take longer to heat up. It's drilled out so it can't completely close.
    Though it's a moot point as you can get fail safe thermostats that will go all the way open if they fail, as their default position. Old thermostats all the way closed was the default position.
    2009 Subaru Impreza WRX STI
  9. #9 Re: Which t-stat should I get?
    Apr 2008
    Indiana
    Quote Originally Posted by Sabrewings View Post
    It heats up the at the same rate it just opens sooner I live in Indiana and I don't notice any differences in the winter with the 160 in
  10. #10 Re: Which t-stat should I get?
    Barksdale AFB, LA
    Maybe I had a bad one, but the drilled thermostat I put in my Silverado kept it from warming up as fast in the winter.
    Either way, its true intention is to allow a small amount of coolant through to keep the heads cooler instead of a stand still of coolant which can heat soak them. That way, when the thermostat does open, the heads are ready to go instead of being extremely heat soaked and in need of cooling.
    The holes are not large enough to make a big difference if it sticks shut.
    From Wizbang at EasyPerformance:
    The 180ºF thermostat was modified by drilling four small hoses around the thermostat body to permit a small amount of coolant flow through the cooling system even when the thermostat is closed. This modification results in reducing the thermostat's opening reaction time when the engine is relatively cool to begin with and is then challenged with prolonged wide open throttle runs. Without a drilled thermostat, the temperature of the cylinder heads can become quite elevated before the thermostat has a chance to open and establish coolant flow through the heads to cool them down.
  11. #11 Re: Which t-stat should I get?
    Aug 2008
    ok so i think im gonna go for the drilled tstat
  12. #12 Re: Which t-stat should I get?
    GT Level Member adidasdude1061's Avatar
    Jul 2008
    P-Town, MN
    what's the stock tstat set at for temp?
    '97 BLACK GTP--Chrome K&N CAI--3.5" MPS--3" RT Cat Downpipe--180*Tstat--Tuned PCM--Alpine 9886--Kicker Amp - 2 12" Kicker L7's--ALT boost&rewire
  13. #13 Re: Which t-stat should I get?
    Jul 2008
    Dekalb, IL
    195*
  14. #14 Re: Which t-stat should I get?
    PA
    Does anyone know why they want to get a cooler t-stat? Do you know why you want your engine cooler?
    The entire colder t-stat idea is to prevent KR. The colder the engine is, the less KR you should get. But if you mod correctly and tune your car, you should not have any KR to contend with. Thus you should be able to run a stock t-stat and get better mileage and better performance.
    My personal opinion is stick with a stock temp t-stat.
    2001 GSE
  15. #15 Re: Which t-stat should I get?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by Zef_66 View Post
    Excellent point. Most folks do not want to take the time to "think" about what they are doing to their car, and why.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  16. #16 Re: Which t-stat should I get?
    you do know cars are faster when the engine is colder, right?
  17. #17 Re: Which t-stat should I get?
    Aug 2008
    im getting the tstat because i am going to be dropping pulley sizes soon after i get the plog, tstat, and colder plugs... im not just doing it for the hell of it
  18. #18 Re: Which t-stat should I get?
    Jul 2008
    Dekalb, IL
    Screw efficiency I want performance . But no really, when I changed to a 180* stat I didn't notice a change in fuel economy at all. No doubt the colder stat will lower gas mileage, but the change in fuel economy will be so miniscule that most people won't notice a change at all. So in my eyes a 180* stat is totally worth it, even if the gains are minimal at least it's something.
  19. #19 Re: Which t-stat should I get?
    Apr 2008
    Indiana
    Quote Originally Posted by Smokin2000gtp View Post
    When I took the advice of a supposed tuner (no longer around) and dropped tstat and plug sizes I lost some serious mileage but my mods are listed in my sig 160 degree Tstat and AL 103 and with a GOOD tune I am getting 30mgh highway with 3 kids and related items for the kids at 70mph the lowest I get is 20mpg and thats beating on the car all the time if ur in it for good mileage DON'T MOD THE CAR
  20. #20 Re: Which t-stat should I get?
    Banned
    oswego
    Quote Originally Posted by black.gtp View Post
    ^^ That's it people, it's just that easy. For real though... i've seen worse...
    This idiot said... "I want my car to be reliable, so what mods are reliable? I plan on drag racing it, but i want a reliable car that won't fail on me"
    F-ING LOL!! Then don't mod and drag race the car stupid!!! man i attacked this poor kid to the max. Or the idiots that cry about the extra $2 per tank to run premium gas... hey morons, if you can't pony up the doe, why the **** did you buy a gtp?! ahh!!! Those people are the worst for me, i will make them think twice before they EVER start another post haha. to them!
  1. 180* T-stat
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 10:30 PM
  2. 180* T-stat
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2008, 06:03 PM
  3. t-stat ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-29-2008, 11:30 AM
