Thread: L36 LIM Install
Results 1 to 5 of 5
  1. #1 L36 LIM Install
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    So the car is a 01 gt with 107k on it and i decided to install a P&P LIM for a few horses as an excuse to replace some seals. In doing so I had to remove the UIM/TB assembly, serpentine belt, idler pulley, alternator. I have two questions:
    1. I have a small spring about .5" long and .25" dia left over. I have no idea where it came from and I have the car back together and running without it. Anyone know where it came from or if its important?
    2. I have a coolant leak coming from the passenger side since the install. But as far as I know the only part of the LIM that has coolant flow through it on that side is the small plastic elbow connected to the coolant manifold by the idler pully. That plastic elbow appears to be dry both times I've checked it, any other ideas?
    Thanks in advance.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  2. #2 Re: L36 LIM Install
    Barksdale AFB, LA
    The spring could be the PCV valve spring...
    2009 Subaru Impreza WRX STI
  3. #3 Re: L36 LIM Install
    Apr 2009
    Georgia
    cool, i'll check that. anyone have any ideas about the leak? its leaking pretty heavily. But that plastic coolant elbow still appears to be dry. where else could it be coming from?
  4. #4 Re: L36 LIM Install
    Barksdale AFB, LA
    There isn't really anywhere from the LIM it could be leaking on that side except the two coolant elbows. Did you check both?
  5. #5 Re: L36 LIM Install
    Yeah I was gonna say. Coolant elbows tend to crack too...might check for leaks there.
  1. 04+ HUD Install
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-06-2012, 02:25 PM
  2. please help!!! cai install
    By BIGTMANE in forum General Tech Discussion
    Last Post: 06-05-2009, 05:27 PM
  3. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  4. need help with LOC install!!!
    By riceburner in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2008, 04:00 PM
  5. Cam Install Kit- What do I really need?
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 01:40 PM
