Thread: I Need A Hand
Results 1 to 7 of 7
  1. #1 I Need A Hand
    New York
    Ok since i bought this car it has randomly just shut itself down, it doesnt matter whether its hot or cold, dry or wet, fast or slow, long drive or short drive, ive racked my brain for any solution i could think of but the issue im having is that there is no common factor when it dies and mechanics always do some bull fix and say there ya go and most times they jus mess up other things but never the main issue i need fixed if anyone has any ideas about this problem please share it with me thanks =)
  2. #2 Re: I Need A Hand
    SE Level Member Ryan D.'s Avatar
    Ft. Wayne, IN
    Loose ground somewheres? Check your battey terminals and block grounds.
    05 Grand Prix GXP
  3. #3 Re: I Need A Hand
    TDCRacing
    Guest
    Bad ICM (ignition control module)
  4. #4 Re: I Need A Hand
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    ^ Both the above are likely culprits, and the crank position sensor may also be a possibility (very common on these cars).
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  5. #5 Re: I Need A Hand
    May 2008
    McHenry IL
    agreeed check the CPS!
  6. #6 Re: I Need A Hand
    New York
    OK thanks guys jus thought i should add that it throws no codes jus got it inspected
  7. #7 Re: I Need A Hand
    Dec 2008
    Naperville, IL
    My CPS was flaking out on me for months. Never threw a code (and I've heard the same for countless others with a bad CPS). Also, the coils & ICM don't throw codes.
  1. HOW TO: Hand polish engine parts
    By stlmo_gtp in forum How To Write-Ups/Tech Tips
    Last Post: 04-09-2010, 09:37 PM
  2. Just some opinons for hand guns
    Last Post: 02-16-2009, 05:06 PM
  3. Hand brake?
    By whiteknuckle in forum Brakes/Suspension/Chassis
    Last Post: 02-09-2009, 02:34 AM
  4. How much Dex 6 to have on hand to fill dry trans?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2008, 01:34 PM
  5. Wideband - first hand experiences please?
    By IndeedSS in forum PCM Tuning
    Last Post: 03-04-2008, 08:44 PM
