Thread: 1.95 yella terras and 105 springs...
Results 1 to 16 of 16
gotboost3 1.95 yella terras and 105... 06-27-2009, 10:40 AM
Bio248 Re: 1.95 yella terras and 105... 06-27-2009, 12:31 PM
gotboost3 Re: 1.95 yella terras and 105... 06-27-2009, 04:44 PM
Bio248 Re: 1.95 yella terras and 105... 06-27-2009, 04:51 PM
blueguy Re: 1.95 yella terras and 105... 06-27-2009, 05:24 PM
gotboost3 Re: 1.95 yella terras and 105... 06-27-2009, 06:19 PM
gotboost3 Re: 1.95 yella terras and 105... 06-27-2009, 06:22 PM
Guest Re: 1.95 yella terras and 105... 06-27-2009, 06:28 PM
Scimmia Re: 1.95 yella terras and 105... 06-28-2009, 01:13 AM
Guest Re: 1.95 yella terras and 105... 06-28-2009, 08:06 AM
Guest Re: 1.95 yella terras and 105... 06-27-2009, 06:32 PM
EmEaston24 Re: 1.95 yella terras and 105... 06-27-2009, 11:25 PM
Guest Re: 1.95 yella terras and 105... 06-28-2009, 08:04 AM
blueguy Re: 1.95 yella terras and 105... 06-28-2009, 02:43 AM
Scimmia Re: 1.95 yella terras and 105... 06-28-2009, 10:32 AM
Sabrewings Re: 1.95 yella terras and 105... 06-28-2009, 04:27 PM
  1. #1 1.95 yella terras and 105 springs...
    Donating Users
    Plainfield, IL
    what kind of gains would i see from the title? i'd rather go rockered so i dont have to pay 500$ for a cam install...the rockers i can do myself....ive heard gains around 20-25 WHP is this true?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: 1.95 yella terras and 105 springs...
    those rockers and those springs are going to cost as much as doing a cam. otherwise yes, youll probably gain a good 20 whp out of them.
    you sure you want to trust comp 105s?
  3. #3 Re: 1.95 yella terras and 105 springs...
    Donating Users
    Plainfield, IL
    what if i just got 1.8 roller rockers and kept the stock springs....or 1.9 modified....what kind of gains do the modified rockers offer?
  4. #4 Re: 1.95 yella terras and 105 springs...
  5. #5 Re: 1.95 yella terras and 105 springs...
    Stay away from Comp Cams 105's...they have been snapping.
    If you are going to run high ratio ROLLER rockers instead of the modded rocker arms...then I'd spring for some LS6 Springs and retainers...you can get a set of LS6's off of EBay for about $50-$70 ish...they equate to 90# springs. You should be able to get the retainers from a local dealership for about $20-$30...I run LS6's with my XP Cam setup...also before the XP swap I ran 1.84:1 Yella Terra Roller Rockers with stock springs shifting at 6200. Not as nice as the cam, but cruising on the HWY, I got about 3-5mpg's MORE with the rockers
  6. #6 Re: 1.95 yella terras and 105 springs...
    Donating Users
    Plainfield, IL
    so basically a good bang for your mod is 1.84 roller rockers because i can put them in myself and run stock springs? or should i save for the XP it would be about 775$ installed lol thats a lot...
  7. #7 Re: 1.95 yella terras and 105 springs...
    Donating Users
    Plainfield, IL
    you think i could get away with a 3.0 on an XP with 42lb inj? non ICed...or would i prob be around a 3.2? what pulley could i drop to with 1.84 rr?
    mods would be the rockers plus my sig and a tune from FASTKATT..same if i had the cam...
    or should i say **** a cam and just get ICed ? decisions decisions...
  8. #8 Re: 1.95 yella terras and 105 springs...
    TDCRacing
    Guest
    I can promise you guy's that if comp had an issue with there springs and we know about it. So do they. And if they know about it then it has been taken care of. You guy's don't realize the kind of quality control that these springs go through before they are released.
    I mean there is this big old thing about the new 125's or what ever in the hell they are. Those springs go through the same process when being made. I have used many set's of 105's. Comp 105's. And never had an issue. I agree with everyone else that it is 100% user install error. And when it comes down to a tech standpoint these springs are not designed for our application. They are designed for a ls1 application.
    I have never heard of anyone on here or any of the other forums actually having an issue with there springs breaking. Except club GP. And there it was a very limited number of people. Everyone just seems to like to talk about it.
  9. #9 Re: 1.95 yella terras and 105 springs...
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by TDCRacing View Post
    I has been posted about constantly from dozens of people on other boards. This was a huge issue with the Comp 130s with the LSx guys, and Comp acknowledged the problem and replaced a TON of springs. They obviously didn't take care of the problem, though, as springs continued to break outside of the batches they were replacing. It's not just some rumor as you insinuate, it's a very real problem. When they switched suppliers from PAC to some factory in Mexico, everything went to hell.
    2001 Buick Regal LS - Almost Stock
  10. #10 Re: 1.95 yella terras and 105 springs...
    TDCRacing
    Guest
    Quote Originally Posted by Scimmia View Post
    Would you trust any of the springs? OR are there just some of the springs that are made in that factory?
  11. #11 Re: 1.95 yella terras and 105 springs...
    TDCRacing
    Guest
    Oh, And BTW get a cam.
  12. #12 Re: 1.95 yella terras and 105 springs...
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    not trying to thread jack but since the topic is rockers n such can someone tell me what kind of rockers these are...
  13. #13 Re: 1.95 yella terras and 105 springs...
    TDCRacing
    Guest
    Quote Originally Posted by EmEaston24 View Post
    Those look like harland sharp rockers.
  14. #14 Re: 1.95 yella terras and 105 springs...
    ^^Yup...I heard that whole story minus the factory swap part. Got a buddy that is on LS1tech and all he tells me is how people with their high lift cams keep snapping comp springs over, and over, and over...hence why if you get springs...get GM Issue LS6 (90#) Springs, or the Crow 105#'s. I've heard nothing but good things from Crow.
    And for the pic...those look like Harland Sharp Rockers.
  15. #15 Re: 1.95 yella terras and 105 springs...
    QCA, IA
    At this point, I wouldn't trust any Comp springs made in the last three years or so. I can't tell you what's made where for sure, but I do know that Comp switched totally away from PAC somewhere in that time frame, so even if they're not Mexican made, Comp springs in the last three years aren't the same as Comp springs made before that. ZZP's description of the Crow springs suggests that they're PAC springs, so I would probably go that way, or with a different manufacturer like Si. There's always the L76 spring option for high ratio rockers, too.
  16. #16 Re: 1.95 yella terras and 105 springs...
    Barksdale AFB, LA
    L76 springs FTW! Top notch quality on the cheap.
    2009 Subaru Impreza WRX STI
  1. 04+ HUD Install
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-06-2012, 02:25 PM
  2. please help!!! cai install
    By BIGTMANE in forum General Tech Discussion
    Last Post: 06-05-2009, 05:27 PM
  3. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  4. need help with LOC install!!!
    By riceburner in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2008, 04:00 PM
  5. Cam Install Kit- What do I really need?
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 01:40 PM
