Do you have enough coolant in there? Do you have an coolant overflow bottle? The fans could be the issue. One easy way to check them is to turn your a/c on. Both fans should come on whether you just started the car and it's cold or if the car is hot. IF they don't both come on then that is your problem. Other wise you might just have to watch for the fans to come on after it gets to 210.
