Thread: Cooling fan swtich
Results 1 to 11 of 11
  1. #1 Cooling fan swtich
    GT Level Member bkaab's Avatar
    Adrian MI
    I have had some problems with my 3100 heating up a little at ideal. I just had the intake and head gasket replaced. Right now the right fan will kick in when it gets between 210 and the next mark on the gauge. The fan will shut off when it gets below 210. But then in 5-7 min it gets hot enough for the fan to kick in again and does the same thing.
    I want to run a switch inside the car to turn on the fan manually. How do you do this and how hard is it?
    Also I have a 195 t stat I am thinking that I am going down to a 180 to help this too.
    Remember its only high 40's-50's here right now and its getting hot I can't think of how it would be when its 80's-90's.
    Thanks for your help.
    '01 GP GT Topswap GT
    '95 GP GTP 3.4DOHC V6
    '95 GP SE Gone but not forgotten.
  2. #2 Re: Cooling fan swtich
    thermostat will help. i dont know if id always want to flip my high speed fan switch on and off all the time just to make the car run cool.
  3. #3 Re: Cooling fan swtich
    Adrian MI
    I am fine with switching it on and off.
  4. #4 Re: Cooling fan swtich
    Oklahoma
    Moved this over to the tech lounge.
  5. #5 Re: Cooling fan swtich
    SE Level Member UWISHU1's Avatar
    Hanover Park, IL
    subscribing, I saw a write up for this somewhere and thought I had book marked it and now I can't find it.
  6. #6 Re: Cooling fan swtich
    Adrian MI
    I found a write up of it on v6 z24 forum
  7. #7 Re: Cooling fan swtich
    Saraland Alabama
    make sure the system is bled properly, but also note that is technically how the system should work at idle (you have no airflow helping keep things cool) I hate the manual fan controls if you aren't racing it is a band aid only (racing you leave them on after shutting down the engine)
  8. #8 Re: Cooling fan swtich
    Adrian MI
    Quote Originally Posted by archemedes View Post
    I am going to the track in a week so. THe system is all good.
  9. #9 Re: Cooling fan swtich
    Saraland Alabama
    I just see it on the Camaro boards since alot of guys have senders go bad, and they are too lazy to fix it (it bugs me when someone rigs their car to work rather than fix it right)
  10. #10 Re: Cooling fan swtich
    Adrian MI
    Mine is not broke. The fan turns on and all but I would like to have it one earlier then what it is and when I am sitting at ideal
  11. #11 Re: Cooling fan swtich
    Bastard Reptile's Avatar
    Kansas City, MO
    Here is a writeup for 97-03 W-bodies courtesy of OQCGP
    OQCGP :: Ontario Quebec Club Grand Prix
