Well what are the codes? How are they "pending"? They tell you the second they read them...
Dunno, That's what the guy said but the codes are P0305 (misfire detected in cylinder #5) and P0128 (Coolant temp is always low). The coolant one should be easy to fix, it's either a bad thermostat or needs more coolant.The misfire is what's botherin me I can't figure out what's causing it.
Seaform was suggested to me but I dunno alot about it. It would be easier and cheaper than replacing the fuel injector.
The SeaFoam is like 13 bucks a can here in Canada, worst you can do is put it in and it cleans up your fuel system, but look at the butterfly in the plenum, that's where most of the build up was, on mine anyway.
Good luck.
