Quote Originally Posted by Mercenary View Post
Dunno, That's what the guy said but the codes are P0305 (misfire detected in cylinder #5) and P0128 (Coolant temp is always low). The coolant one should be easy to fix, it's either a bad thermostat or needs more coolant.The misfire is what's botherin me I can't figure out what's causing it.
Seaform was suggested to me but I dunno alot about it. It would be easier and cheaper than replacing the fuel injector.
ICM? And are you sure it is the T-Stat and not the actual sensor in the radiator?
