Thread: Aftermarket PCM Installed
Results 1 to 4 of 4
  1. #1 Aftermarket PCM Installed
    Saskatchewan
    I was wondering if someone can help me out I recently installed an overkill PCM and now the car will not start.
    Thanks
  2. #2 Re: Aftermarket PCM Installed
    Donating Users
    Plainfield, IL
    1. disconnect battery
    2. Install new computer
    3. Reconnect battery
    4. put emergency brake on to disable daytime running lights
    5. make sure all doors trunk and hood are closed leave driver window down and reach in threw window
    6. try to start. If it doesn't start, leave the key in the on position for 10 min on 97-03 cars and 15 min for 04 and newer cars. The security light should turn off after this amount of time.
    7. turn off ignition for 3 seconds
    8. Try and start the car. It probably won't start. Repeat step 5 two more times.
    9. If this doesn't work disconnect battery for 5 seconds and then try and start the car.
    Notes: If your car starts at any time and stays running, you are done. If your car starts and dies, try step 9. If it dies after 2 seconds after you have done these steps, you either have a bad FP resistor or the security setting in your PCM is wrong and it will need an update. Security relearn procedure will not work with the valet key!
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  3. #3 Re: Aftermarket PCM Installed
    Saskatchewan
    Ok I will try that after lunch thank you very much for your help
  4. #4 Re: Aftermarket PCM Installed
    I live here. UR LOSN's Avatar
    Rockford, IL
    some cars have problems starting after a PCM install, others.... are plug and play.
  1. TDC FWI installed
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 10:49 AM
  2. Stb's Installed
    By TML529 in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2009, 12:39 AM
  3. Got the new DP installed, but...
    By the1euge in forum General Tech Discussion
    Last Post: 07-21-2008, 08:07 PM
  4. First Mod installed. CAI
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 08:41 AM
  5. Just installed wizaired CAI
    By 3800SE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2008, 07:46 PM
