a press is needed to do the snout, if you use a hammer you can damage the bearings. now the needle bearings you could proly get away with a brass hammer. i did on mine because the press i used had to much slop in it and the bearing was going sideways! Use some oil to help the bearings slide in better and measure with calipers the depth of the old bearings before taking them out of the housing.
