Thread: HELP please..Question regarding hub bearings
Results 1 to 4 of 4
  1. #1 HELP please..Question regarding hub bearings
    GT Level Member TJs97's Avatar
    NJ
    What are the tell tale signs that your front hubs are bad? My GTP has a BAD vibration while accelerating thru 35-45 MPH. You can't really feel it in the steering wheel..you just feel it. Its almost like a HORRIBLE bad tire wobble but its definetly not a tire. It happened w/the stock wheels/tires and the dealer said it was a bad rim..so I swapped wheels/tires w/my 97 GTP and its still there. Brought it to my mechanic and he says the LF Hub is bad.
    Would a bad hub do this? Or should I be looking at something else on top of the hub? Thanks
  2. #2 Re: HELP please..Question regarding hub bearings
    Oklahoma
    Thats not a typical sign of a bad wheel bearing. Having experienced that vibration at those speeds I can tell you that it is likely one of the axle shafts. I had two 4-wheel alignments done and then also was told it was a bad wheel. I replaced the inner and outer tie rods, replaced the transmission mount, lower and upper motor mounts and the ball joints.
    Ultimately it was finally fixed by replacing the CV/axle shafts. I dont know which it was as I replaced them both at the same time.
  3. #3 Re: HELP please..Question regarding hub bearings
    Barksdale AFB, LA
    Axle shaft, most likely one of the inner (tripot) joints. Mine was the passenger side, but I replaced both anyway.
    2009 Subaru Impreza WRX STI
  4. #4 Re: HELP please..Question regarding hub bearings
    Oct 2008
    Canada
    Bearings are easy to check. Jack up the suspect wheel, put hands at 12 and 6 position and try to twist the wheel in and out from the top and bottom. If you feel ANY losseness or hear noise then your bearing is toast.
    When mine went I could hear a roar from the offending wheel, kinda like if you had snow tires on during summer. Its pitch would change depending on wheel speed and I could hear it through all speeds.
    Noise during certain speed bands is usually a drive shaft CV joint.
    2001 Grand Prix GT (Stock)
    1998 Grand Prix GT (SLP CAT Back, MSD Coils, 8mm Wires, Platinum +4 Plugs, All Options)
    1996 Sierra K1500 6.5L Turbo Diesel
  1. question
    By gtpinsc in forum Brakes/Suspension/Chassis
    Last Post: 09-19-2008, 08:02 PM
  2. Wheel Bearings/Hubs
    By bcrosby51 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:49 PM
  3. M90 Rotor Bearings
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 02:17 PM
  4. Rotor pack bearings
    By marchi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2008, 05:36 PM
  5. LED question
    By bula81069 in forum Visual/Body Modifications
    Last Post: 04-15-2008, 10:03 AM
