Thread: Will a 99 N/A gp maf work ok 98 GTP
Results 1 to 5 of 5
  1. #1 Will a 99 N/A gp maf work ok 98 GTP
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    wondering if it would work on a my 98 GTP so I could put a 99 pcm in
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: Will a 99 N/A gp maf work ok 98 GTP
    GTP Level Member Scimmia's Avatar
    QCA, IA
    the MAF is the same between the L36 and the L67, but the housing on the 97-98s is different than the 99-03s. You could use the 99 L36 MAF only if you have a 99+ TB.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Will a 99 N/A gp maf work ok 98 GTP
    Really. I could have sworn the MAF's were completely different due to the larger bore TB. You 100% sure on that?
  4. #4 Re: Will a 99 N/A gp maf work ok 98 GTP
    QCA, IA
    I've got one from each sitting in my living room right now, they are the same.
  5. #5 Re: Will a 99 N/A gp maf work ok 98 GTP
    Barksdale AFB, LA
    He's right. The one from my L36 works perfectly in my L67 TB. Also they're the same part number.
    Why would the MAF itself need to be different for a larger bore? It's the MAF table in the PCM that would need to be different.
    2009 Subaru Impreza WRX STI
  1. my way to work
    By mileyguard in forum Off Topic Discussion
    Last Post: 03-25-2009, 09:33 PM
  2. Will this work??????
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2008, 08:40 AM
  3. Work
    By TheOtherNick in forum The Rant Forum
    Last Post: 10-14-2008, 09:30 PM
  4. G.I. In Fab work
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 06-27-2008, 10:33 AM
  5. Will this work?
    By sra_chipmunk in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2008, 09:12 AM
