Thread: Another 16.4 post.
Results 1 to 8 of 8
  1. #1 Another 16.4 post.
    Outer Space
    I know the response will be vac leak, but hear me out.
    I took the car to the shop on monday to get it smoke tested. They could not find a leak. I sprayed everything I could. Even replaced some of the T's. Never affected idle.
    Coolant/Oil levels are fine ever since my LIM change. But I had to replace a TB gasket cause I found a leak. Also, found one at the EGR block offplate, but I got it sealed now.
    Since I can't find a leak after a thorough carb cleaner bath, what should I check next?
    My LTFT's at 16.4 on idle on my "box tuned" pcm, however, when I scaled the MAF it gets/feels alot better. Only thing that looks bad is Decel...
    Do you ONLY get 16.4 when you have a vac/exhaust leak? Or can it be attributed to other things... like adding headers...etc.
    I have thoroughly read the 01+ fuel dump issue, and I have tried 98 files...etc with the same result.
    Anyone in the Southeast wanna make some money before I put this thing in a ditch? LOL
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: Another 16.4 post.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by Lawngoose View Post
    Leaky headers can do it, a screwy MAF and/or MAP could do it, and a bad tune of course could do it, a modified throttle body without compensating in the computer would do it, etc. Vac leaks are the most common reason, but not the only one.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Another 16.4 post.
    Outer Space
    I have pace****ters, that have been welded up. MAF has been replaced, I guess I could clean it. Still have the factory MAP (128k) on it. And the stock TB.
  4. #4 Re: Another 16.4 post.
    Donating Users
    Plainfield, IL
    Quote Originally Posted by Scimmia View Post
    wouldnt a bad map or maf throw a code???
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  5. #5 Re: Another 16.4 post.
    Donating Users
    Plainfield, IL
    thanks for this post i spent forever looking for my vac leak and it was my LIM egr block off plate...now i just gotta get that shyt to seal....
  6. #6 Re: Another 16.4 post.
    Yes, but I think the MAF or MAP have their own specific codes...
  7. #7 Re: Another 16.4 post.
    QCA, IA
    They could once they get bad enough the computer knows that it's a false reading, but if the reading's just a little off, how would the computer know?
  8. #8 Re: Another 16.4 post.
    Outer Space
    I guess I could throw a new MAP sensor in there. I mean ... i am rich... lol
    I stuff a different tune on my car... and i am running better... but still have a stumble from 2-3 on part throttle.
  1. First post for me...
    By djaustin907 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:40 AM
  2. 1st Post
    By cmw1876 in forum Off Topic Discussion
    Last Post: 09-03-2008, 10:59 AM
  3. first post here
    By The_Avenger in forum Introductions/Noob Questions
    Last Post: 03-25-2008, 12:24 PM
  4. Had to post this
    By 19SE92 in forum Off Topic Discussion
    Last Post: 02-18-2008, 09:44 PM
  5. First post! HUD.
    By gmboy in forum Visual/Body Modifications
    Last Post: 12-13-2007, 08:44 PM
