Thread: Ignition Problem-Please Help
Results 1 to 20 of 21
  1. #1 Re: Ignition Problem-Please Help
    GTP Level Member dstout's Avatar
    ky
    Have you checked the battery cables for corrosion? You might try scraping the insides of the clamps and get some new lead exposed and scrape off the battey posts so you get a good connection. Also check the ground wire and see if that didn't come loose somewhere.
    If those things are alright try jiggling the key in the ignition cylinder it could be the ignition cylinder where something didn't set right when you turned the car off last nite.
    Has your key ever gotten stuck in the ignition and you couldn't get it out?
  2. #2 Re: Ignition Problem-Please Help
    Florida
    Thanks for giving me a starting point everyone and thank you for the other links. I will post to those today also. A friend will be coming over this afternoon to see if he can help with this problem.
    I have had this car only for 3 weeks and have not had a problem yet with the key sticking. I called the previous owner and she states that she never had the problem either. She was a 70 year old woman.
    The battery is spotless. Actually everything under the hood is spotless. When I removed the battery there was no corrosion at all.
    I tried all day on Sunday jiggling the key, moving the shift back and forth making sure that the car is in park and praying that the car will miraculously start. Didn't work. The last time that I got into the car yesterday, there were no chimes. Nothing. I am thinking it is the ignition, that something blew in it the last time that I shut it off. I cant be sure because I had 4 children in the car at the time, (2 are mine and their friends) but I thought when I went to start it on Saturday morning that I heard a pop when I turned the key and then nothing.
    My last car was an Olds Aurora that I had for 12 years and believe me I had my share of problems with that car and I have become very familiar with the engine area of the car. I am not afraid to get under the hood and learn how to fix the problem.
  3. #3 Re: Ignition Problem-Please Help
    ky
    This must be very discouraging and aggravating for you seeing you just bought it a few weeks ago. It doesn't sound like it was an abused car if you bought it from an older lady. For a 97 with 47K she must not have driven alot.
    Is there a fuse block under the hood? if so there are relays inside you might check that if you have not by now.
    If the battery and cables are good I wonder if it is inside if the ignition cylinder.
    Do you have a remote start on the car? I had one and it f*cked things up and had to take it off.
    Post to the other sites and see if someone there might have an idea I will keep looking and ask around.
    Hope you guys can figure something out.
  4. #4 Re: Ignition Problem-Please Help
    ky
    If you do end up needing some expensive part and you can wait a day or two try Ed Morad he deals in Pontiac parts and has very good prices. Ed will have what you need if he doesn't he will find it. He is very good to work with.
    A $1,200.00 part cost me 175.00 delivered.
  5. #5 Re: Ignition Problem-Please Help
    ky
    I think it just pulls out, the ign main could be the problem. I think you could test it or have someone else test it maybe Napa.
    I think you would need a multi meter to test it with but I don't know what pins to test so I'm not much help with that.
  6. #6 Re: Ignition Problem-Please Help
    ky
    here is another link it might have something there.
    ClubGP Message Forum troubleshooting
  1. I can't take my key out of the ignition!
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-06-2010, 11:10 AM
  2. Ignition problem ICM or fuse?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2009, 11:41 AM
  3. Help IGNITION KEY PROBLEM
    By cool50 in forum General Tech Discussion
    Last Post: 02-28-2009, 11:57 PM
  4. Ignition Problem.
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 07:49 PM
