Thread: weird noise coming from engine
Results 1 to 10 of 10
  1. #1 weird noise coming from engine
    Luke AFB
    I need any advice on my 2006 grand prix, when my engine is cold and up to the first 3 miles I have a weird sound that sounds like an electric motor whenever I press the gas peddle, any clues or sugguestions to what this might be
  2. #2 Re: weird noise coming from engine
    Feb 2008
    Well, your car does have the electronic TB. It could be that motor that moves the TB.
  3. #3 Re: weird noise coming from engine
    Luke AFB
    thanks, ill look into it
    Loud music, roaring engine and nowhere to let go..
  4. #4 Re: weird noise coming from engine
    Luke AFB
    looked into the etb and its on the wrong side of the engine for the sound i had the belt and water pullie replaced and the noise hasent ceased
  5. #5 Re: weird noise coming from engine
    Barksdale AFB, LA
    Probably the power steering pump. Is it good on fluid?
    2009 Subaru Impreza WRX STI
  6. #6 Re: weird noise coming from engine
    Luke AFB
    Its got plenty of fluid, it only makes a noise when the gas is applied evin when driving in a strait line, i havent had any problems with the stearing,
  7. #7 Re: weird noise coming from engine
    Feb 2008
    Sabre might be on to something with the PS pump. They can make noise even when not turning and with little to no noticeable function change. (Fords do it coming new from the factory! ) Water pumps could make noises like that as well (you said you replaced the water pulley?????) not sure what that means. I supposed the S/C could possibly make that noise too if the bearings are bad.
  8. #8 Re: weird noise coming from engine
    Barksdale AFB, LA
    My PS pump makes a slight whining noise and it's fine. Has for years. Volume depends on temperature.
  9. #9 Re: weird noise coming from engine
    Luke AFB
    It does get quiet when it gets warm but its so loud that it makes me wonder if somethings wrong, ill have to get it swapped out to be shure
  10. #10 Re: weird noise coming from engine
    SE Level Member JoeMama's Avatar
    Houston, TX
    Mine had a slight whine from the PS pump too... had it for years too. Finally went out and am going to replace it before putting the engine back in.
  1. Grinding noise coming from my engine
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 04:24 PM
  2. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  3. weird ticking noise coming from turbo
    By lilredss0287 in forum Turbo
    Last Post: 09-05-2008, 08:56 PM
  4. Weird noise. Dropped the car in second.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-04-2008, 12:26 PM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
