Sabre might be on to something with the PS pump. They can make noise even when not turning and with little to no noticeable function change. (Fords do it coming new from the factory!) Water pumps could make noises like that as well (you said you replaced the water pulley?????) not sure what that means. I supposed the S/C could possibly make that noise too if the bearings are bad.
