Thread: Grinding noise coming from my engine
Results 1 to 6 of 6
  1. #1 Grinding noise coming from my engine
    SE Level Member zeppelinrocks18's Avatar
    Okay, so I have noticed a sort of grinding noise and vibration when the car is sitting a stop light. At first I suspected power steering fluid was low but that did not fix it. I have noticed it only does it in gear. When it is in park, it will not make the grinding. It goes away when I accelerate. I have been told it might be my supercharger bearings. I am checking on here to see everyone's input and if there is an easy way to tell what it is and fix it. I'd appreciate any help. Thanks.
    1998 GTP, 118K, Short Ram Air Intake, ACDelco RapidFire Plugs, Belden Wires, Resonator and U-Bend delete, Flowmaster Original 40 Series, KYB GR-2 Struts, 180* Thermostat
  2. #2 Re: Grinding noise coming from my engine
  3. #3 Re: Grinding noise coming from my engine
    mounts?
  4. #4 Re: Grinding noise coming from my engine
    Dec 2008
    Wilmington, NC
    I'm having the same probs too...I know I need a S/C coupler...but that shouldn't be causing the car to vibrate...I think the mounts need to be replaced. I got to get my mechanic to look at it when he does the S/C coupler
  5. #5 Re: Grinding noise coming from my engine
    It's not vibrating the car the way it sounds. I can feel the grinding through the car. Vibrating is the wrong word. I think it's something in the engine like the S/C coupler or bearings.
  6. #6 Re: Grinding noise coming from my engine
    Dec 2008
    Wilmington, NC
    I'm getting a new S/C coupler installed this weekend...I'll let you know if it fixes the prob...
  1. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  2. 98 engine noise
    By jbizach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2008, 07:18 AM
  3. My engine tapping noise with Video
    By 04CompG in forum General Tech Discussion
    Last Post: 12-12-2008, 02:57 PM
  4. weird ticking noise coming from turbo
    By lilredss0287 in forum Turbo
    Last Post: 09-05-2008, 08:56 PM
  5. Engine noise help please.
    By mathd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-01-2008, 08:50 AM
