Thread: Tilting motor forward
Results 1 to 13 of 13
  1. #1 Tilting motor forward
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    A simple tool i use to help tilt the engine forward in my gp (shoot, should work for more than that, depending on the engine mount configuration) I use a ratchet strap from the engine lift point to a heavy duty bracket on the front wall of my garage. I've tried to use the ratchet strap from the engine bracket to the radiator core support, but find that it is a bit too close for the ratchet straps i have.
    YMMV, you may be able to use the core support.
  2. #2 Re: Tilting motor forward
    PA
    I do the same thing, but I use my 6" vise that is bolted to my work bench that is bolted to the wall. Works great!!
    2001 GSE
  3. #3 Re: Tilting motor forward
    Saraland Alabama
    a friend of mine that works at a dealer had some nice pics of a car they used the core support, and the weight of the engine against it bent it (really good since it was warranty work being done doh)
  4. #4 Re: Tilting motor forward
    SE Level Member NickT'sGTP's Avatar
    Cedar Rapids, IA
    All I did was undo the front dog bones and have someone rock the car and when the motor is in the right orientation you hit the e-brake.
    1998 Grand Prix GTP - 12.699 @ 108.84 - 1.931 60 ft - Gone.... but not forgotten....
    2005 Impala SS - 14.790 @ 94.35 - 2.262 60 ft - 100% Stock
  5. #5 Re: Tilting motor forward
    SE Level Member GP_Kid18's Avatar
    May 2008
    Palatine,Illinois
    Quote Originally Posted by NickT'sGTP View Post
    dose the E-brake hold the motor in place?
    also my brothers friends are mechanics and they told me that there is a tool the you put in place of the dog bones and you crank it one way to pull the motor to the front and crank it the other way to push it back
  6. #6 Re: Tilting motor forward
    PA
    Quote Originally Posted by GP_Kid18 View Post
    With all four wheels on the ground, you unhook the dogbones. This allows the engine to move some. Then push the car a little. The force from the front wheels will push the engine back and forth. Just push the car until the engine tilts forward. Then set the e-brake so the car will stay in the exact same spot. As long as all four wheels are on the ground with the e-brake set, the engine will stay in the same spot.
    2001 GSE
  7. #7 Re: Tilting motor forward
    GT Level Member DesQ27's Avatar
    May 2008
    Kennewick
    Why is it a good idea to tilt the motor??
    "True measure of a man's strength is his self control in time of great stress" - ME
    2002 GTP: U-Bend and Resonator Delete; Mufflers Modded; K&N Short Ram Air; WS6 Ram Air Hood
  8. #8 Re: Tilting motor forward
    Barksdale AFB, LA
    Yes, because the engine tilted forward when the front wheels rolled forward while you rocked it. The e-brake holds the car still, so it keeps the front wheels from moving and the engine from returning to its original position. To move it back, release the e-brake and the tension in the lower mounts will move it back to approximately where it should be.
    2009 Subaru Impreza WRX STI
  9. #9 Re: Tilting motor forward
    Moore, Oklahoma
    I've used racheting straps before. Works good
    I usually just undo/remove the drivers side torque strut, replace stud/nut on engine bracket, undo passenger side torque strut by the coil packs, i use a long pry bar and insert it on the drivers side engine mount between the mount and stud, pull it towards me, and use the single top stud hole by the coil packs and insert the stud through the bracket and torque strut. Works great for me too. I've done this many times too.
    Shawn W. Larsen
  10. #10 Re: Tilting motor forward
    SE Level Member BigG's Avatar
    St. Louis
    Quote Originally Posted by Iron Indian View Post
    I like the **** out of that!!! I'm gonna try that next sparkplug change.
  11. #11 Re: Tilting motor forward
    Nov 2008
    Chicago
    I wish I'd seen this a few hours ago.
  1. will a 03 gtp motor work in a 98 gtp????
    By gtpmadman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 11:05 AM
  2. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
  3. Tilting 9007's!
    By Toasty in forum Visual/Body Modifications
    Last Post: 03-25-2008, 07:59 AM
  4. Motor Trend First Look '09 ZR-1...
    By newfie in forum Off Topic Discussion
    Last Post: 01-23-2008, 07:58 AM
  5. Pics of motor
    By RED GTX in forum Turbo
    Last Post: 01-22-2008, 08:26 PM
